Introduction: Amazing Money Printer
Want to be cool to your friends, Youtube fans, etc.? This is a cool project that is easy to build, plus only requires very simple items!
Step 1: Print Out a Black Sheet of Paper Doublesided
Any color is fine, but black works best in this case. If you do not have a duplex printer, you may print one side and put the sheet back in the printer and print the other side.
Step 2: Cut the Paper
Cut the paper into two strips. I am using a paper cutter, if you don't have one, you may use scissors. Also, trim off the sides so that the white part is not shown.
Step 3: Tape the Two Sheets
Make a long strip of paper by taping the two strips together.
Step 4: Roll It Up Up Up!
Tape the strip, then roll it up into a stick, I am using a pencil, you may use any stick that is long enough. Leave at least an inch unrolled to make the next step easier.
Step 5: Roll Another One
Roll the end to another stick shown in the picture. It must be rolled like shown in picture.
Step 6: Case It
You may make a cardboard case, wooden case, or whatever case that fits. If needed, place a base board.
Step 7: Insert a Dollar Bill
Insert a dollar bill and turn the stick. Call the end the knob. Turn the knob so the dollar bill will go all the way inside.
Step 8: Show Off
Place a paper on the opposite side that you placed the dollar. Then turn the knob and there comes the dollar bill! Now show off to your friends by doing Step 7 and this step.
