Introduction: Amazon Dash Button Lamp Control
The Amazon Dash button is a great new device that can be bought for only $5. Very shortly after the release of it the first working hack of it was published online. It showed you how to detect when the button was pushed on your computer and to launch a program in response to it using a few lines of python code. I was very impressed with the hack and I wondered if I could make it run something on hardware instead. My first thought was the Raspberry Pi.
In this tutorial I will show you how to use a Raspberry Pi with the Dash Button to control a lamp or any other electronic device.
Step 1: Materials
Material List:
1.Raspberry Pi-I would recommend using the new Raspberry Pi 2 or you could use the B/B+.You will also need the basics for it such as a mouse,keyboard, power supply, and display.
2.Amazon Dash Button-Any product button will do, just make sure to not set it up when you get it.
3.PowerSwitch Tail II-This is used by the Raspberry Pi to turn on and off any AC electronic device.
4.SD Card-You will need to install a fresh copy of Raspbian onto it. Make sure that it is 4GB or more.
5.Wifi Adapter-This is to make sure that your Raspberry Pi can connect to the internet to recieve an ARP probe any time the button is pushed.
6.Raspberry Pi ribbon cable-this is not needed if you want to solder or use alligator clips to connect the PowerSwitch Tail to your Raspberry Pi's GPIO connectors.
7. Any AC Device- this is up to you to decide what device you want to turn on. I will use a my bedroom lamp for this experiment.
Step 2: Raspberry Pi Setup
To start off you will need a SD card with Raspbian installed. I would highly reccomend using this Instructable from Beta Mode on how to do this-Link
Once it is setup boot up your Raspberry Pi and go through Raspi-config to make sure all your settings are set to the default. Then type startx to launch the desktop. You will need to connect to the internet. You can find the network manager in the Acessories pane of the start menu. Once you connect to wifi we will need to log off and go back to the terminal view. We will then need to download the necessary packages:
Scapy:
This is a python library that allows you to scan for ARP signals from the Amazon Dash button.
To install scapy use the following command:
sudo apt-get install scapy
GPIO Library:
This is a python library that allows you to control the gpio pins of your Raspberry Pi.
To install it use the following commands:
wget http://pypi.python.org/packages/source/R/RPi.GPIO...
tar zxf RPi.GPIO-0.1.0.tar.gz
cd RPi.GPIO-0.1.0
sudo python setup.py install
Once we finish this we will have the ability to use our Raspberry Pi to respond to the Amazon Dash Button.
Step 3: Setup the Amazon Dash Button.
To enable our Dash button to communicate we will need to set it up first.
To start off download the Amazon App on your phone and login to your Amazon account.
On the app click the menu button in the upper right corner. Then click the Your Account option and scroll down to the Dash Devices group. Click the "Set up a new device" button.
Follow the below steps to setup your button:
- Click the Get Started button.
- It will then ask you to type in the Network name and Password of your network. Enter this and click continue.
- Hold your dash button until the light on it starts to flash blue.
- Turn up the volume on your phone and set the Dash button next to your phones speaker and click the next connect button.
- Once it connects, it will ask you for a product do not select a product instead close the app out.
Great! Your button is now hacked!
We will then need to program your Raspberry Pi.
Step 4: Program Your Raspberry Pi
To start off we have to scan for our Amazon Dash button's IP Adress.
We will have to use the code from the original hack of the Dash Button:
from scapy.all import *
def arp_display(pkt):
if pkt[ARP].op == 1: #who-has (request)
if pkt[ARP].psrc == '0.0.0.0': # ARP Probe
print "ARP Probe from: " + pkt[ARP].hwsrc
print sniff(prn=arp_display, filter="arp", store=0, count=10)
This will scan for the Amazon Dash Button's ARP Signals on the network and return the MAC Adress of our button.
After running this program we will copy the MAC address and add it to a modded version of the original hack.
Save this as scan.py
Open a new terminal and use the "cd" command into the directory where you saved scan.py
To run the program type sudo python scan.py
When the program is finished copy the MAC address into the next program.
import RPi.GPIO as GPIO
GPIO.setup(18, GPIO.OUT)
if pkt[ARP].hwsrc == 'MAC Address': # Button MAC Address
GPIO.output(18, True)
else:
print "ARP Probe from unknown device: " + pkt[ARP].hwsrc
This program will allow you to turn pin 18 on when the button is pushed.
Save this as button.py
Proceed to the next step.
Step 5: Run the Program.
To sucessfully run the program we need to hook up our PowerSwitch II. Connect your GPIO ribbon cable to the connector on your Raspberry PI. Connect a wire from pin 18 on the GPIO Cable to the PowerSwitch tail to the + wire of the PowerSwitch Tail and the ground to one of the ground pins on the GPIO connector. Connect your PowerSwitch tail to an AC outlet on your wall and connect the other side to your AC Device.
Start the program on the Raspberry Pi just like the scan program. Once it is running, push the button on your Amazon Dash Button and watch the device turn on!
Thank you for reading my Instructable and please vote for it in the Raspberry PI Contest!
Step 6:
![First Time Author Contest](https://content.instructables.com/FO9/OWVL/IDK2L5XC/FO9OWVLIDK2L5XC.jpg?auto=webp&frame=1&width=320)
![Raspberry Pi Contest](https://content.instructables.com/FG9/XR97/IDA2KMOM/FG9XR97IDA2KMOM.jpg?auto=webp&frame=1&width=320)
