Ammo Box Speakers
Intro: Ammo Box Speakers
I need some speakers that would withstand some weathering and look nice in the my new jeep. So I used some old military ammo boxes and so 6x9 speakers.
If you like this project or have question please feel free to leave a comment!
Thanks
Thanks
STEP 1: Materials
2 - 6x9 speakers I use some cheap ones from walmart for $24
2- Military Ammo Boxes Pawn Shop 4.99
1- Can Black rustoleum $3
1- Dip it rubber coating $4
STEP 2: Cut First
The 6x9 speakers will come with a template which you can lay directly on the box. Make sure you center the speaker and have the handles facing the way you want. Trace template on speaker then use a grinder, drimmel , or Drill to open up a place to start. Once you have a starting point you simply follow the template line you traced with a jig saw.
STEP 3: Sand, Paint, and Mount Speakers
Now its time for paint I went with paint/rubber spray/paint gives it some texture and hopefully makes it a bit stronger. Lay the speaker in the hole after paint has dried and use a marker to mark where holes should be drilled for screws. Also at this point dill out a hole for the speaker wire to come through. Then give all edges a good sanding before mounting the speaker.
STEP 4: Wire
Wire speakers and turn it up to 11...
23 Comments
bucko92 11 years ago
packrat666 11 years ago
onemoroni1 11 years ago
bobbybedard 12 years ago
Dr. Science 13 years ago
motaaa 14 years ago
try cutting an old pillow open and stuff the ammo boxes with the pillow stuffing, itll stop the boxes from vibrating so much and makes the low tones sound alot better. just my .02
emergencydpt.com 14 years ago
JoeMurphy 14 years ago
hellstudios 14 years ago
in one of these.
That is, once I get a car. lol
abadfart 14 years ago
kurisu2 14 years ago
pdlbooboo 14 years ago
JZ Price 14 years ago
JamesRPatrick 14 years ago
