Introduction: An Led Light Up
I just made an led light up for funzies
all you need is a resistor, a 9v battery, any color led, 2 male to female wires, and 1 female to female!
Step 1: Conect the Battery
to connect the battery, simply touch the male end of the wire to each terminal, make sure the positive and negative are correct!
Step 2: Connect to the Resistor
to connect your battery to the resistor, put the positive end on either side using the female end of the wire as shown above.
Step 3: Connect to the Led
attach the female to female wire to the led anode side and run your other with from the negative battery terminal to the cathode side of the led.
