Straightening and Stiffening a Wire (enderezando Y Haciendo R�gido Un Alambre).
Intro: Straightening and Stiffening a Wire (enderezando Y Haciendo R�gido Un Alambre).
EDITED 05 feb 2011:
I discovered, years ago, an easy, cheap and efficient way to straighten and stiffening a wire:
An end of the wire is put in the electrical drill, the other end to some hook or vise, tense the wire and rotate the drill a few turns.
The result is surprising.
This method is useful to construct axes or straight rods, and even to make springs. It can be used on thick (all you can manage, obvious) or thin wire.
That is all, folks.
Descubrí, hace años, una forma fácil, barata y eficaz de enderezar y dar rigidez a un alambre:
Un extremo del alambre se pone en el taladro eléctrico, el otro extremo se fija a un gancho o a la morza, se tensa el alambre y se gira el taladro unas pocas vueltas.
El resultado es sorprendente.
Este método es útil para construir ejes o barras rectas, e incluso para hacer resortes. Se puede utilizar en alambre grueso (todo lo que uno pueda manejar, obvio) o delgado.
Eso es todo, amigos.
That is all, folks.
74 Comments
aqua-regia 2 years ago
enVide neFelibata 12 years ago
rimar2000 12 years ago
Alywolf 8 years ago
yes please do the instructable on how you twist both
rimar2000 8 years ago
Sorry, Alywolf, I will not do that. Please use your imagination, it is very simple.
Alywolf 8 years ago
aww but you said that you might above. thats ok, I am really good at figuring things out on my own anyway.
Countrywings 9 years ago
If you twist wires in a drill (to make twisted pairs for a radio speaker, for example) you can pass a heat gun or hair dryer over the wire (taking care not to melt the insulation) and then let it cool, keeping it under tension as it cools. The result will be wire that stays twisted. Or, simply allow the twisted wires to remain under tension for a while, and then release them. It might untwist a little, but should not be extreme.
rimar2000 9 years ago
Thanks for the suggestion. In the case of a pair of wires, I twist them separately. This is a lot toilsome if they are long, like a cord extension for mower. I tie an end, ask help to my wife or somebody to hold it and I go twisting both single ends while she goes turning her end.
graydog111 9 years ago
Great idea, Rimar. Can't wait to try it.
batonas 11 years ago
rimar2000 11 years ago
jdennis7 11 years ago
doo da do 11 years ago
The Green Gentleman 11 years ago
