Introduction: An Inspiration of Friendship Fbracelet Making Ideas With String
This is an inspiration of bracelet making ideas with string, and in this tutorial I will show you the friendship bracelet knots instructions in detail. So that with simple material and less cost, you can create a fantastic bracelet.
Step 1: Prepare Materials and Start to Braid
Prepare three long strings with different color. Start from the middle with flat knot, braid until it can form a small circle and then braid it into a ring. Put the string symmetrical.
Step 2: Work the Knot
1. Pick up the orange string as working line and yellow string as holding line and do an overhand knot. The right side does the same.
2. Now you can see the two white strings in the middle, pick up the left one as working line and the right one as holding line to make two overhand knots as picture shows.
3. Put the white lines away and we still treat them as working lines and make two overhand knots not only on yellow line but also on orange line, so does the other side.
4. Yellow lines turn in the middle and they will be the holding lines, the two orange lines as working lines, each of them braid an overhand knot on the yellow lines.
Step 3: Do the Ending Work
When the bracelet is long enough and fit for your wrist, divides the six strings into two parts and braid three-ply braid and tie overhand. Snip the excess part and fusion use the lighter.
bracelet making ideas with string has done! Hope you can like it and the friendship bracelet knots instructions can help you and motivate your talent to create more bracelets.
