Introduction: Analog Joystick #HMS2018
you will need one Elegoo Uno R3 adruino, one Elegoo joystick module, and 5 Female to Male DuPoint wires
Step 1:
Connect the first cable (I used green) to the SW port on the analog module and the 2 port on the arduino.
Step 2:
Connect the second wire (I used yellow) to the VYR port on the analog module and the other end to the A1 port on the arduino.
Step 3:
Connect the 3rd wire (I used orange) to the VRX port on the analog module and the A0 port on the arduino.
Step 4:
Connect the 4th wire (I used red) to the +5V port on the analog module and the other end to the 5V port on the arduino.
Step 5:
Connect the 5th cable ( I used brown) to the GND port on the analog module and the GND port on the arduino.
Step 6:
Connect a power cable with a larget power adapter on one side and a standard USB on the other end.
Step 7:
When you are done it should connect to the tablet or other device by going into the USB port. You download the files from the website Elegoo.com, which, incidentally, is the company from which I got this product. The files include instructions on how to make the analog joystick work as a mouse or a controller. Sadly, I was not abel to show that as my tablet does not support those types of files, even though it is a PC. So I used my other PC at home. It is a very complex progrtam and I am stil working on it. Hopefuly I can get vit working over the spring break.
Step 8: The End
The finished product.
