Introduction: Androino! Control an Arduino From Your Android Device Using a Cheap Bluetooth Module.
This instructable shows you how to read sensor values from an Arduino with your Android device using a cheap bluetooth serial device you can order for under $10 on dealextreme or ebay.
This example uses Python as the scripting language for the Android scripting layer (SL4A) but you can choose from other languages like Perl, Lua, JavaScript etc. see: http://code.google.com/p/android-scripting/
Step 1: You Need:
1. JY-MCU bluetooth wireless serial port module.
http://www.dealextreme.com/p/jy-mcu-arduino-bluetooth-wireless-serial-port-module-104299
or search for "bluetooth module" on ebay
I've bought mine for $8.20 on dealextreme.
2. An Android device with bluetooth.
3. An Arduino board.
4. Some sensor or potentiometer to read values from.
Step 2: Setup the Arduino Hardware
The BT module comes preprogrammed with the following settings:
Device name: linvor
Baud rate: 9600
PIN: 1234
You can leave the settings as they are or change them with a serial adapter.
For more info see: http://wiki.openpilot.org/display/Doc/Serial+Bluetooth+Telemetry
Connect the bluetooth module to your Arduino.
BT module Rx-> Arduino Tx
BT module Tx-> Arduino Rx
VCC to 5v
GND to GND
Connect a sensor or potentiometer to analog pin A0.
Upload this sketch to your Arduino: http://pastebin.com/raw.php?i=xmyr840j
The onboard LED at D13 is toggled everytime a sensor value is requested from the Arduino.
Step 3: Setup the Android Device
Install Android Scripting Layer and Python for Android:
http://code.google.com/p/python-for-android/
(This instructable is based on SL4A r4)
Copy the code from http://pastebin.com/raw.php?i=FVxKzf1g
and name it androino.html
Copy the code from http://pastebin.com/raw.php?i=XEmEsATU
and name it androino.py
Change the BT_DEVICE_ID in androino.py to the address of your BT module.
If set to None, Android will ask you at program start which bluetooth device to use.
Upload both files to the /sdcard/sl4a/scripts/ directory on your phone.
Step 4: Have Fun
Turn on Bluetooth on your Android and pair the device using the pin 1234.
Start SL4A on your Android device.
Select androino.py and then the gear symbol to start the application.
The SMD LED on your BT module should stop blinking at this point.
A WebView is started and when you click on the button, the sensor value gets read and displayed.
It's really that easy :)
SL4E API reference:
http://www.mithril.com.au/android/doc/
edit:
I've added this script which simply dumps anything that is send via serial out from your arduino.
dump.py http://pastebin.com/raw.php?i=uVxaD829
Select dump.py and then the console icon in SL4A to start.
Arduino Challenge
51 Comments
8 years ago on Introduction
find the code given in below link and troubleshooting techniques and circuit diagram
http://knowledge-cess.com/arduino-android-interfacing-example-code-and-troubleshooting/
nice!
What do you mean by "sensor" ?
9 years ago on Introduction
The bluetooth module does not work with arduino micros's RX and TX pins, but I does work with software serial. Any advice on that, anyone? I can't use software serial as I need the PWM pins for other stuff...
9 years ago on Step 4
Hello Friend, I am doing a mechanical arm, and I wonder how I control the servos via Bluetooth? Has a model Tutorial?
thank you
can I test this application with hyper terminal in windows ?
i make a connection between mobile bluetooth and my labtop
and select the com port of the Bluetooth in hyper terminal
but when i open the mobile application to send any thing from the terminal as a test before connecting the arduino
The application cannot start
it gives me w white screen with no thing else
I installed the sl4a r4 and python interpreter
but the problem still exists ?
10 years ago on Step 2
Hi metanurb,
I have the exact bluetooth module that you have but I can't send anything to this module. Below is simple echo code that I use. Have I missed anything?
Thank you.
Arduino mega 2560
const int LED_PIN = 13;
boolean toggle = true;
void setup() {
Serial1.begin(9600);
void loop() {
if (Serial1.available()) {
Serial1.println(Serial1.read());
digitalWrite(LED_PIN, toggle);
toggle = !toggle;
delay(1000);
10 years ago on Introduction
With ArduinoDroid (https://play.google.com/store/apps/details?id=name.antonsmirnov.android.arduinodroid) you can develop for Arduino on Android:
HI ..
please tell the program for arduino to transfer accelerometer sensor value serially using a bluetooth ttl interface
My bluetooth module is discovered by Nokia feature phone but Samsung Galaxy Ace can't find it. FYI, Ace is running on Android GingerBread 2.3.6. Is there any problem with class parameter of Bluetooth module?
My module's documentation goes here :http://www.robokits.co.in/documentation/Bluetooth%20UART%20Module%201545.pdf
I think this will be helpful to lot of other undocumented module owners cause I have similar module.
Is there any idea how to make it discovered by Android?
I have done everything in the tutorial, but I don't get any values. The bluetooth does connect because the blinking led on the bluetooth module stops blinking and stays on. But I do not get any values. I have the HC-06 2.0 bought from ebay. Any ideas of what might be wrong? Am a total noob at this. Thanks anyway
I used the code below with the programs and scripts you provided. It should work right? What am I doing wrong? Please someone help, I really want it to work. I am using:
"HC-06 Bluetooth V2.0 RF Wireless Transceiver Module Interface RS232 TTL"
This is my code:
#define trigPin 13
#define echoPin 12
const int LED1 = 8;
int sensorValue = 0;
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LED1, OUTPUT);
void loop() {
if (Serial.available()) {
Serial.read();
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
// delayMicroseconds(1000); - Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance >= 200 || distance <= 0){
Serial.println("Out of range");
digitalWrite(LED1, LOW);
else {
Serial.print(distance);
Serial.println(" cm");
digitalWrite(LED1, HIGH);
sensorValue = Serial.print(distance);;
digitalWrite(LED1, toggle); // toggle the LED
toggle = !toggle;
delay(500);
Great stuff! Thank you so much! :)
10 years ago on Step 4
Hi!
Is there any way to just send serial command to arduino like the serial monitor in the IDE?
Anyway, Pretty neat instructable....
I am using Samsung galaxy note 2. when i run androino.py i get a black screen and then crashes,"unfortunately, SL3A has stopped." any solution?
Nice instruct able. I do have one issue, when I run androino.py it doesn't open the html in a WebView, I see it in plain text :(. Any ideas?
Excellent, thanks for this - managed to tx/rx data dynamically between my website and my pad and the Arduino - fantastic - thanks again!
One question, as my Python scripting is not that hot - if I wanted to connect multiple bluetooth modules e.g. 2+ and route them all through my pad to my website how would I poll each module? something like this?.....
For x = 0 to (amount of bluetooth modules)
If BT(x) connected/success Then .....
TX/RX
End If
Loop
Thank you for this. I have a problem, I loaded everything as per your instructions including the device I. When i load the androino.html it just opens the html file in text form. Is my android O.S. to old? Thanks
hello i have been having trouble with youre code . every time i run the androino.py code i get this Message
[SyntaxError: can't assign to operator (androino2.py, line 13)]
line 13 is the line where i am assigning the BT_DEVICE_ID.
Thanks for such a straightforward tutorial - I feel like an idiot having issues, where everyone else seems to have succeeded!
When I open SLA4, all I see is the html file, not the py file, which is defininately in the same directory as the html one...
Any thoughts on where I've gone wrong?
Thanks in advance :)
