Introduction: Angel Tea Light
An angel tea light, for my angel of course! Also planning on using these for stocking stuffers at Christmas.
Designed using Autodesk Fusion 360, sliced using Ultimaker Cura 4.12.1, and printed in PLA Ultimaker S5s.
Step 1:
Simply two pieces to print, and a tea light to purchase (I used a "flickering" effect tea light).
Prior to assembly, test fit and trim, file, sand, etc. both parts as necessary for tight fit . Depending on the colors you chose and your printer settings, more or less trimming, filing and/or sanding will be required.
After clean up, press "Angel Tea Light Small.stl" into "Angel Tea Light Small Base.stl".
Test fit your tea lamp in "Angel Tea Light Small Base.stl". The base opening for the tea lamp is 40mm in diameter which was chosen after a few different brands of tea lights were tried. Some brands fit tight, others fit loose. If your tea lamp is loose, wrap tape around the circumference of the tea lamp base until a tight fit is attained.
I hope you enjoy it!
