Introduction: Angel With Tatted Wings
I made these angel using beads from an old belt and a bit of crochet cotton. I think they turned out pretty well. They were intended as Christmas ornaments but they can be used to decorate other things as well.
Since this is so small, it is a good beginner project.
Step 1: Materials:
Beads for the body
Head pins--at least 2 inches
Round-nosed plyers
Tatting shuttle (or tatting needle)
No. 10 crochet cotton (or whatever you have on hand)
Super glue
White glue
Paint brush
Straight pins
Round-nosed plyers
Super glue
White glue
Paint brush
Straight pins
Step 2: Body
I make the body first since I want to make the wings fit the size of the body.
I used beads from a hideously ugly old belt. Once I took it apart, the beads themselves were very nice. I used gold flat beads as halos. I had some plain wood beads for the heads.
Once they were strung, I curled the leftover wire from the head pin around the round-nosed plyers to make a hanger loop.
Step 3: Wings
I tatted the wings but you could also crochet them. If you don't have the tatting or crochet skills, you can find a piece of lace to use as the wings.
The pattern that I made up was pretty easy. I made a few variations, but here is the pattern I liked best:
Ring 1: 9 dh, 1 p, 3 dh, close ring
Ring 2: 3 dh, join to last p, 3 dh, 9 p, 3 dh, 1 p, 3 dh, close ring
Ring 3: 3 dh, join to last p, 3 dh, 3 p, 3 dh, 1 p, 3 dh, close ring
Chain: 3 dh, 5 p, 3 dh
Ring 4: 6 dh, join to last p, 3 dh, 1 p, 6 dh, close ring
Chain: 10 dh
Ring 5: 3 dh, join to last p, 3 dh, 5 p, 3 dh, 1 p, 3 dh, close ring
Chain (center): 5 dh
Ring 6: repeat ring 5
Chain: 10 dh
Ring 7: repeat round 4
Ring 8: repeat ring 3
Ring 9: repeat ring 2
Ring 10: 3 dh, join to last p, 9 dh, close ring
Fasten the tails and trim.
Note: dh stands for double hitch
p stands for picot
Chain: 10 dh
Chain: 10 dh
p stands for picot
Step 4: Attach Wings
Super glue the wings onto the middle of the body. Whichever side you glue them to becomes the back. I use super glue gel because it stays in place better. If you only have the thin super glue, I would probably find another strong type of glue. The gel takes a while to dry.
Step 5: Stiffening the Wings
Mix white glue with water--about equal parts (it really doesn't matter if you are exact).
Cover the ironing board (or other pin-able surface) with plastic. I used a plastic grocery bag.
Pin the wings to the ironing board using straight pins.
Paint the glue/water mixture on the wings. After letting the liquid soak into the fibers for a few minutes, gently blot with a tissue. This will force a bit more liquid into the fibers as well as remove the excess liquid from the lace. If you leave the liquid filling in the middle of the rings, you may end up with a thin film of dried glue that could be visible in the final angel.
Allow to dry. Paint a second coat if you want the wings a bit stiffer.
