Introduction: Anna's Coronation Hairstyle (Frozen-inspired)
Do you have little fans of Frozen at home? I do, two of them in fact, and they love the costumes and props from this movie. Princess Anna from Frozen wears a special hairstyle to her sister's coronation and even though it looks complicated, it's not. Let's see how to make it.
The hairstyle is basically a bun with spiraled ponytail around it and a braid around the head from ear to ear. Anna wears bangs but no need to cut it just because of one hairstyle.
As you can see this is a hairstyle for long hair. If your girl's hair isn't long, you could consider clip-on extensions.
Did you know that I have a bunch of tutorials on costumes? You can check them out here! And you might be interested also in my Faux Mohawk Hairstyle.
- 10-15 bobby pins
- green ribbon
- small clear hair elastics
- comb
- a little water
Step 1: Upper Section
1. Comb the hair well and dampen it a little, a spray bottle would be the most practical for this.
2. Separate a section from just above the ear (on both sides) as if you were to make a half updo.
3. Put them together into a half ponytail.
Step 2: Make the Braid
1. Take one section of hair from just behind one ear and start braiding. Hold the braid upwards while braiding.
2. Make a braid all the way to the end of this hair strand.
3. Pull on the sides of the braid carefully to make the braid wider and more voluminous.
4., 5. Lead the braid over the head behind the other ear and pin it with a bobby pin there (red arrow) and also on the top of the head.
Step 3: Make the Bun
1. Split the loose hair in two sections and unite them above the ponytail.
2. Then add the ponytail to them and start twisting the hair towards one side. The hair in the center should lift a little and create a bun.
3. Twist the ponytail around the bun pinning it with bobby pins all around. Pin the end of the ponytail inside the bun or rather under it so it doesn't show.
4. If you find the bun is too small, pull it carefully with your fingers.
5. Fold the ribbon in half and "thread" it on a bobby pin where the fold is. Pin this bobby pin with the ribbon in the lower part of the bun.
I hope you enjoyed this instructable and it wasn't too difficult, was it? :-)
