Introduction: Anti-Grief
For this you will need:
-Sticky Pistons
-Cobblestone( or any type of building material)
-Red stone
-Red stone Torch
-Repeater
-switch
Step 1: Roof
Start out with a roof of the size of your liking and leave a trail of cobblestone
Step 2: Piston
Place a rectangle of cobblestone and place 2 or more sticky pistons
Step 3: Redstone
Put the red stone behind the piston to connect it together
Step 4: Support
Add 2 more levels so the water can go there and the water at the top
Step 5: Stairs
Make stairs so the redstone can flow down
Step 6: Path
Make the redstone path and stop wherever you are
Step 7: Repeator
Put the repeaters down.
Step 8: Switch
Put a switch at the end so you can turn it off and on
Step 9: Test
Test your invention so you can see if it works
Step 10: Walls
Always protect your red stone from the water
