Introduction: Anti Star-ship-bug Robot_part_I
i have find out that i could use a DIP SW to do a multi-program mode.
and i have find out that i could use whithout SW(s) to do a multi-program mode !
Step 1: How to Avoid the One From Dying
i am figuring about the man who launch the star-ship out,
i am wondering how to protect the one who launch the star-ship.
in order to protect the the star-ship to shot the chip-bug to dead of the star-ship at once!
in the outer space! what if the chip is gone dead?
that how to protect the one who launch the star-ship from the chip gone dead .
There is no redundent chips in outer space so the solution is the auto-multi-task chip (Multi_Function for all) for reuse in the other system.
For example : the O2 generator is down or was broken. the astronauts will die in minutes. (All for all) that how to protect the one who launch the star-ship from the O2 generator gone dead now?
the answer : remove the chip out of food processor, and plug it onto the socket on the O2 generator board !
Step 2: Materials
1) pico / pico w / pico-zero (rpi2040)
2) pin(s)
Step 3: Soft? It's Kind of HDCPU.(hardware Define CPU)
Write the main program(s) for every function board(s).
but allow one only by PCB jumper on board that decide which program the board told CPU how to decide which kind of board the CPU is setting on right now!
so, HDCPU.(Hardware Define CPU) is the same as SDCPU(Software Define CPU) !
in order to raise the portable of CPU in everywhere(everyboard).
That is to say:
and in order when the AI ROBOT can fix the damage board of the star-ship quickly at once during the battle.
Step 4: Ware? It's Kind of SDCPU.(Software Define CPU)
but allow one only by PCB jumper on board that decide which program the board told CPU how to decide which kind of board the CPU is setting on right now!(who has been grounded)
That is to say:
Step 5: Test Run
life is in seconds during the battle !
maybe there are someone wondering about
how does it work:
because the pico(RP2040) have a python mode .
so i use the python mode to define the pin 2, pin 3, pin 4 to independent from the main program
and circuits from the pico(RP2040).
EX:the pin2 is define as JUMPER3 (AS a virtural jumper)
JUMPER3 = Pin(2, Pin,IN,Pin.PULL_UP)
means the CPU will do temperature meter while JUMPER3 GROUNDED
and get reception the JUMPER3 GROUND, and the CPU will do temp program then !
so then the CPU knows whitch board is setting on now !
in the video above , since when i swap the two pico and the sence of CPU knows each !
when they touch the board and auto change the (CLOCK and COUNTER) program was
run in the same time when they connect the board.
