Introduction: App for Mobile Control LED(Arduino+Bluetooth Module)
Hello,
In this i will explain how to code for Android app in Android Studio.
For Arduino code and circuit, refer...
https://www.instructables.com/id/Mobile-Control-LEDAndroidBluetooth
Step 1: Creating New Project(LED Control)
Download Android Studio, install and open it
- create new project.-name LED Control
- Select minimum SDK to target
- create blank activity named list
Step 2: Design the List Activity
Now design list activity as shown in fig. above.
Or directly copy the code in Text from the file provided in last.
Step 3: Coding for List Activity
package com.example.kulwinder.ledcontrol;
import android.bluetooth.BluetoothAdapter; import android.bluetooth.BluetoothDevice; import android.content.Intent; import android.support.v7.app.AppCompatActivity; import android.os.Bundle; import android.view.View; import android.widget.AdapterView; import android.widget.ArrayAdapter; import android.widget.Button; import android.widget.ListView; import android.widget.TextView; import android.widget.Toast; import java.util.ArrayList; import java.util.Set;
public class list extends AppCompatActivity {
ListView list;
Button paired; private BluetoothAdapter adapter = null;//Represents the local device Bluetooth adapter
private Set paireddevices;
public static String EXTRA_ADDRESS = "device_address";//use to store MAC address of connected device @Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_list); //Calling the widgets
paired = (Button) findViewById(R.id.paired);
list = (ListView) findViewById(R.id.listView); //if the device has bluetooth
adapter = BluetoothAdapter.getDefaultAdapter(); if (adapter == null) {
//if no adapter/device availabe
Toast.makeText(getApplicationContext(), "No Bluetooth Device available", Toast.LENGTH_LONG).show();
finish();
} else if (!adapter.isEnabled())//if adapter is available
//Ask to the user for turning on the bluetooth
Intent i1 = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);//intent use for to atrat new activity
startActivityForResult(i1, 1);
} paired.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
pairedDevicesList();//call function
//function
private void pairedDevicesList() {
/*Once you have the local adapter, you can get a set of BluetoothDevice objects
representing all paired devices with getBondedDevices() */
paireddevices = adapter.getBondedDevices();
ArrayList alist = new ArrayList(); if (paireddevices.size() > 0) //if paired devices are there
for (BluetoothDevice bt : paireddevices)
alist.add(bt.getName() + "\n" + bt.getAddress()); //Get the device name and the address
else
Toast.makeText(getApplicationContext(), "No Paired Bluetooth Devices Found.", Toast.LENGTH_LONG).show();
// to show a vertical list of scrollable items we will use a ListView which has data populated using an Adapter
The ArrayAdapter requires a declaration of the type of the item to be converted to a
View (a String in this case) and then accepts three arguments: context (activity instance),
XML item layout, and the array of data. Note that we've chosen simple_list_item_1.xml
which is a simple TextView as the layout for each of the items.
final ArrayAdapter adapter1 = new ArrayAdapter(this, android.R.layout.simple_list_item_1, alist);
list.setAdapter(adapter1);
list.setOnItemClickListener(myListClickListener); //Method called when the device from the list is clicked
} private AdapterView.OnItemClickListener myListClickListener = new AdapterView.OnItemClickListener() {
public void onItemClick(AdapterViewStep 4: Design Led Activity
Procedure for new empty Activity shown in fig.
Design led activity as shown in fig.
Step 5: Code Led Activity
import android.app.ProgressDialog; import android.bluetooth.BluetoothAdapter; import android.bluetooth.BluetoothDevice; import android.bluetooth.BluetoothSocket; import android.content.Intent; import android.os.AsyncTask; import android.support.v7.app.AppCompatActivity; import android.os.Bundle; import android.view.View; import android.widget.Button; import android.widget.SeekBar; import android.widget.TextView; import android.widget.Toast; import java.io.IOException;import java.util.UUID;
public class LED extends AppCompatActivity { Button on, off, discon, exit;
SeekBar brightness;
TextView value;
String address=null;
private ProgressDialog progress;//Progress bars are used to show progress of a task.
BluetoothAdapter adapter=null;//Represents the local device Bluetooth adapter
BluetoothSocket socket=null;//socket is an endpoint for communication between two machine
private boolean isBtConnected=false; static final UUID myuuid=UUID.fromString("00001101-0000-1000-8000-00805F9B34FB");
/*the uuid is used for uniquely identifying information. it identifies a particular service
provided by a Bluetooth Device
@Override
setContentView(R.layout.activity_led);//this view our activity Intent newint = getIntent();
/*for receivig data d=from another activity....Here we recieve address of selected paired device
from list activity
address = newint.getStringExtra(list.EXTRA_ADDRESS); //calling the widgets
on= (Button) findViewById(R.id.onbt);
off= (Button) findViewById(R.id.offbt);
discon= (Button) findViewById(R.id.disconnectbt);
exit= (Button) findViewById(R.id.backbt);
value= (TextView) findViewById(R.id.value);
brightness= (SeekBar) findViewById(R.id.brightsb);new connectbluetooth().execute();//calling function to connect
//functions of buttons on CLICK
on.setOnClickListener(new View.OnClickListener() {
@Override
onled();//callinf onled function on click of on button
}); off.setOnClickListener(new View.OnClickListener() {
@Override
offled();
}); discon.setOnClickListener(new View.OnClickListener() {
@Override
disconnect();
}); exit.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) { System.exit(0); brightness.setOnSeekBarChangeListener(new SeekBar.OnSeekBarChangeListener() {
@Override
public void onProgressChanged(SeekBar seekBar, int progress, boolean fromUser) {
if(fromUser==true)//(fromUser)=callback that notifies client when the progress level has been changed
value.setText(String.valueOf(progress));//print seekbar value to text field-value
try
socket.getOutputStream().write(String.valueOf(progress).getBytes());
//send value of progress to bluetooth socket and socket send it to bluetooth module
catch(IOException e)
@Override
public void onStartTrackingTouch(SeekBar seekBar) { } @Override
public void onStopTrackingTouch(SeekBar seekBar) { } });
private void message(String a)
Toast.makeText(getApplicationContext(),a, Toast.LENGTH_LONG).show();
//display the message on screen for 3.5 sec
} private void onled()
if (socket!=null)
try
socket.getOutputStream().write("on".toString().getBytes());
//send "on" to bluetooth module
catch (IOException e)
message("Error");
//send string s="Error"to message function
} private void offled()
if (socket!=null)
try
socket.getOutputStream().write("off".toString().getBytes());
//send "off" to bluetooth module
message("Error");
} private void disconnect()
if (socket!=null)
try
socket.close();
message("Error");
finish();
}//An asynchronous task is defined by a computation that runs on a background thread and whose result is published on the UI thread.
private class connectbluetooth extends AsyncTask
private boolean ConnectSuccess = true; @Override
protected void onPreExecute()
progress = ProgressDialog.show(LED.this, "Connecting...", "Please wait!!!"); //show a progress of connection
} @Override
protected Void doInBackground(Void... devices) //while the progress dialog is shown, the connection is done in background
try
if (socket == null || !isBtConnected)//when bluetooth device not connected
adapter = BluetoothAdapter.getDefaultAdapter();//get the mobile bluetooth device
BluetoothDevice device = adapter.getRemoteDevice(address);//connects to the device's address and checks if it's available
socket = device.createInsecureRfcommSocketToServiceRecord(myuuid);//create a RFCOMM (SPP) connection
BluetoothAdapter.getDefaultAdapter().cancelDiscovery();//it ask for permission...so add it
socket.connect();//start connection
ConnectSuccess = false;//if the connection try failed, you can check the exception here
return null;
@Override
protected void onPostExecute(Void result) //after the doInBackground, it checks if everything went fine
super.onPostExecute(result); if (!ConnectSuccess)
message("Connection Failed. Try again.");
finish();
else
message("Connected.");
isBtConnected = true;
progress.dismiss();//close progress bar i.e. working
Step 6: Creating Apk
Now create apk for the app->
for this go to Build->Build apk
now install the app and enjoy controlling led through mobile.
you can download whole Android file from the link:
https://drive.google.com/open?id=0B4eY-jcXDOueX0M5WFktZHdLQ2s
If any queries feel free to write.
thank you!
