Introduction: (App) Le Pi
Everyone loves Apple Pie. While some like Pumpkin or Pecan Pie, Raspberry or Rhubarb Pie, as a general rule, everyone loves Apple Pie. Modern Times change names of institutions to atrocious miss-spellings or Homophones. So to go with the flow, I am making (App) le Pi.
Step 1: Ingredients
Crust
1 Cup Unsalted Butter
2 1/2 Cups White Flour
1 Teaspoon Salt
1 Teaspoon Sugar
4-8 Tablespoons Cold Water
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
6 or 4 big pared and sliced cooking apples
1 tbsp. lemon juice
(To save time for non-pro members I will put the relevant Ingredients on every page)
1 Teaspoon Salt
1 Teaspoon Sugar
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Step 2: Crust (part 1)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Place the butter in the freezer and wait at least 15 minutes, but the longer the better.
Meanwhile mix the Flour, Salt and Sugar into a large mixing bowl.
1 Teaspoon Salt
1 Teaspoon Sugar
Step 3: Crust (part 2)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Cut the cold butter into cubes about the size of a dice. Mix with the other Ingredients in the bowl. This will be difficult to do however, so be prepared for some hard work. I used a Pastry Kneader, but you could use a food processor. Keep doing this until the butter is in pea-sized balls.
1 Teaspoon Salt
1 Teaspoon Sugar
Step 4: Crust (part 3)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Add 1 Tablespoon cold water at a time and mix. Keep adding water and every once and a while pinch a small amount of dough. If it holds together, the dough is ready.
You should be able to take a fistful and it will hold like in the picture.
1 Teaspoon Salt
1 Teaspoon Sugar
Step 5: Crust (part 4)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Separate the dough into 2 equal parts. Form two disks about one inch thick. Wrap them up and put them in the fridge for an hour or up to two days.
1 Teaspoon Salt
1 Teaspoon Sugar
Step 6: Crust (part 5)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Put a non-stick baking sheet on the counter and sprinkle with flour. If you do not have a non-stick sheet it will be more difficult but still doable. Place the dough on the sheet. Apply flour liberally again and get out your rolling pin.
This is not my picture.
1 Teaspoon Salt
1 Teaspoon Sugar
Step 7: Crust (part 6)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Once the dough has stretched enough (this can be determined by placing your pie pan upside-down on the dough, the dough sheet should be at least 3 inches wider then the pie pan) put the pan upside-down on the dough. Slowly slide the sheet off the counter with one hand, while the other hand supports the pan. Carefully flip the sheet and pan upside down and allow the dough to sink into the pan. Then slowly peel the sheet of the top. Press the dough firmly but carefully into the edge of the pan. Ripping it is not ideal, but if you do rip the crust, a pinch with wet fingers should fix it up. Prick holes in the bottom with a fork.
If you have a 9 inch pie pan, and add three inches to both sides, you get a diameter of 15, which has a radius of 7.5, meaning that pi(r^2) is pi(7.5^2) which is pi(56.25) which means that the crust must have an area of 176.714587inches squared. If you have a 1/4 inch crust, you need 44.17864675 cubic inches of pie dough. Therefore the inverse... 2 hours later.. beepeepeep (smoke alarm wakes up bored chefs to be)
1 Teaspoon Salt
1 Teaspoon Sugar
Step 8: Filling (part 1)
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
(Please remember that apples brown quickly so make haste with this step.)
Mix the sugar, cinnamon, salt and flour in a bowl.
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Step 9: Filling (part 2)
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Peel and quarter the apples. Then cut into thin slices.
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Step 10: Filling (part 3)
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Layer the apples in the pie crust, then put on a layer of the Flour/Salt/Sugar/Cinnamon. Repeat till the crust is full.
Sorry about the picture quality, I only had my phone as the camera was not at home.
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Step 11: Filling (part 4)
^What would I do without Google Images^
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Splash the lemon juice over the apples in the crust.
While you roll the top crust, put the apples in a cool place preferably wrapped up.
Filling
1 c. sugar
1/2 tsp. cinnamon
1/4 tsp. salt
2 tbsp. flour
1 tbsp. lemon juice
Step 12: Crust (part 7)
Crust
1 Teaspoon Salt
1 Teaspoon Sugar
Do the same as before, just it doesn't need to be so thin. Spread the crust carefully over the apples and the bottom crust. Pinch the bottom and top crust together.
1 Teaspoon Salt
1 Teaspoon Sugar
Step 13: Decoration (part 1)
Decoration
1 beaten egg
Now your pie in ready to cook, but you might want to add some twist to it. Some Bakers put sugar on the top. Others put pastry leaves and pastry apples on the crust. In honour of the Rob Janoff and William Jones, the designer and assigner of the Apple Logo and the Pi symbol respectively, I have put the respective symbols on the pi(e), along with pi's numeric abbreviation, 3.14.
Picture is of William Jones.
1 beaten egg
Step 14: Decoration (part 2)
Decoration
1 beaten egg
Cut out the pictures you want out of paper. I used the picture in the Intro. Paint the back of the paper with water and place it in the pastry. Use the tip of a butter knife to cut out the shape. Paint the back of the shape with the beaten egg and place it on the top crust. Paint the tops of all your shapes with egg yolk to make them stand out. The numbers I did freehand.
1 beaten egg
Step 15: Cook
Preheat the oven to 240 degrees Celsius. Put in the pie and wait 25-30 minutes. Then watch till it browns. Poke with a toothpick to see whether the apples are soft enough. Take out with care. It will be hot. Duh.
Step 16: Side
Top off with some delicious ice cream of your choice.
I like to use scoochmaroo's banana ice cream.
https://www.instructables.com/id/1-ingredient-Ice-Cream/
Step 17: Final Picture
Within 5 minutes of cooling.
This is my first Instructable. Please vote.
