Introduction: Apple Oxidation Experiment
In case the video does not load, in order to watch paste the following link into your web browser: https://youtu.be/ldLxmkIWWZs
Step 1: Problem or Purpose
A problem that many people are facing is that their apples are browning quickly once they slice them into different slices and our experiment will conclude the best drink that keeps your apple slices fresh for the longest period.
What is the effect of different drinks on a slice of an apple?
Step 2: Hypothesis
If we add a slice of an apple in different drinks, the time taken for this slice to change color into brown will be different, because apples react differently with different types of drinks whether it was an acidic drink or a basic drink.
Step 3: Variables
Independent: the drinks we will add the apple slices into
Dependent: time taken for the slice to turn brown
Controlled: The freshness of each apple before we start the experiment, the type of apple (red apple), the temperature of the drinks and apples, amount of time to check on the apple slices.
Step 4: Background Research
What causes the apple to start bruising or turn brown is when it is exposed to oxygen, like when it is cut into slices, which causes apple oxidation. Some of the different materials and fluids used to prevent the browning of an apple are lemon juice, water, vinegar, and many more acidic drinks.
Step 5: Materials
1.4 containers
2.Diet 7up, Lemon juice, Low-fat Milk, Coke (1/4 cup each)
3.4 slices of apples
4.Camera/phone
5.Timer
6.Knife to cut apple
7.Measuring cup
Step 6: Procedure
1.Measure the drinks and pour about ¼ of the drinks into each container
2.Slice the apple
3.Place each slice of the apple into the container filled with the drink
4.Set a timer for 2 hours
5.Take notes of the apple with a picture of the slice every 30 minutes
6.After 2 hours have passed, take notes of the apple slice
7.Taste the apple slice to see which one changed the most taste and smell-wise.
8.Fill in the table with the left information and results
Step 7: Data
Step 8: Data 2
Step 9: Graph
Step 10: Data Analysis
From our experiment, we found out that different drinks will cause each apple slice to take a different amount of time to rot, and change color.
After 30 minutes, the apple slice in the diet 7up started turning a bit yellow (Brown Intensity: 20%), tastes like sweet lemon, smells like an apple with a bit of lemon. The apple slice in the lemon juice still looks the same (a white pale color) (Brown Intensity: 10%), tastes like a normal apple, smells like a normal apple. The apple slice in the milk was completely pale white (Brown Intensity: 10%), It tasted like an apple and there was no taste or smell of milk. The apple in the coke started turning brown (Brown Intensity: 30%), it did not taste like an apple but a strong flavor of coke, it smelled like coke and you can hardly smell the apple.
After 60 minutes, the apple slice in the diet 7up became a little more beige looking, (Brown Intensity: 40%), tastes like sweet lemon with a bit of fizz coming from the carbonated soft drink, smells more like a sweet lemon. The apple slice in the lemon juice has barely turned yellow (Brown Intensity: 20%), smells a little bit like lemon, has a hint of sourness. The apple slice in the milk was still completely white (Brown Intensity: 10%), tasted a bit like milk but mostly like an apple, you can hardly smell the milk. For the apple in the coke, it started turning brown (Brown Intensity: 50%), the apple took the taste of the coke and the taste got stronger, it started to smell like coke.
After 90 minutes, the apple slice in the diet 7up started turning a little brown (Brown Intensity: 43%), tastes very soft, also like lemonade with apple, smells a little like 7up and lemons. The apple slice in the lemon juice has started turning yellow (Brown Intensity: 35%), tastes very sour and lemony, smells a lot more like a lemon. The apple in the milk, was still white (Brown Intensity: 10%), the slice slightly tasted like milk but more like apples, it smelled like a bit of milk with apple juice. The apple in the coke’s color was dark from the amount of coke it absorbed (Brown Intensity: 70%), the taste of the coke is extremely clear and you can barely taste the apple, it smelled like coke and a rotten apple.
After 120 minutes, the apple slice in the diet 7up is a light brown (Brown Intensity: 45%), the apple slice is very soft and sweet and took the taste of the diet 7up, smells a lot like 7up and lemons. The apple slice in the lemon juice apple is still the same shade of yellow and has not darkened much (Brown Intensity: 40%), tastes a lot sourer, smells like lemons or lemon juice. The apple slice in the milk’s color was white and did not change at all (Brown Intensity: 10%), it tasted just like an apple with a little stronger taste of milk, it smelled like an apple mixed with milk.
Step 11: Data Analyisis 2
A few mistakes someone can make while conducting this experiment are: using a rotten apple while starting this experiment, using a different colored apple for every drink (when the controlled variable is using the same type of apple), placing the apple and its drink in different weather climates, not putting enough of the drink so it can cover the apple to be able to see some results, etc.
A few ways I can make my experiment better: use apples grown in different locations and places, use red and green apples to see the difference between them, keeping the apple slice in the drink in the fridge or at a hotter temperature to see the difference, etc.
Strengths:
1. This experiment is a solution to a big problem many people face, which is having their apples rot quickly.
2. This experiment was a successful experiment since we ended up with suitable results that can help others.
3. This experiment was done in real life and not digitally so we are sure that the results we ended up with are realistic and true.
Weaknesses:
1. A weakness is that the apples may have shown results if we kept them in the drinks for a longer amount of time.
2. The results may not be as accurate, because there are two different experiments placed in different cities, there is a chance that the weather and climate have an effect on the results of each experiment.
3. Putting an apple slice in a liquid may not be the best solution to keep your apples the freshest since it may not be suitable for kids in school or people transporting from a place to another, since they may not have all the materials and supplies needed.
Step 12: Conclusion
In our experiment, we tested the effect of different drinks on the rotting of an apple. Our hypothesis was correct since the apples were differently affected by the drink, they were put in. Our variables were: Independent, the type of drink, Dependent: the freshness of an apple. Controlled: the type of apple (red apple), the freshness of the apple when we began the experiment, the temperature of the experiment (room temperature). In conclusion, the lemon and the milk did the best job in this case, however, the apple slice that was put in the lemon eventually tasted and smelled only like a lemon. Therefore, milk is our suggested drink for people to use in order to keep the apples fresh since it made the apple stay the freshest and smelled and tasted more like an apple whereas the apple slices in the other drinks took the taste of the drinks and rotted quicker. In addition, milk will preserve the apple from getting brown because it's a basic liquid.
Step 13: Application
Our experiment is important because there are many people who enjoy only a piece of their apple but do not want to complete the whole thing. But the only problem is that when oxygen meets the apple, the apple starts to brown. And we were curious to find a way to avoid this from happening. So, we conducted an experiment, to find out which drink does the best job to keep the apple slice the freshest. Yes, this experiment can be applied with practice to do it correctly without making any mistakes in order to keep your apple slices fresh. After this experiment, we learned that milk and acidic drinks are the best drinks to keep your apple from browning. In addition, milk is the least drink that the apple took the drinks taste and smell.
Step 14: Evaluation
  • Dima: during this project, I have represented a few of the ATL skills. Some are; researching skills, communication skills, thinking skills, self-management skills. I have shown research skills because once we started using different applications such as Instructables, I researched and learned how to properly use it to make sure I submit my assignments properly, as well as, at the beginning of the project we were asked to research our problem, and there I have collected a lot of information online. I have shown communication skills, because, throughout my work in a group, I made sure to stay in contact with my group members to see if I should help them with anything, also to get to know their ideas and opinions about what we are doing. I have also shown thinking skills because in the science fair I thought creatively about unique and different ways to complete my tasks. In addition, when I faced a problem I made sure to think about how I am going to solve it. Lastly, I have shown self-management skills since I submit all my tasks on time and I complete them correctly and the way I was asked to. I depended on myself and I was responsible throughout this project.
  • Allya:research skills, I feel like we used research skills because we researched about our experiment at the beginning to know what the experiment is about. Social skills, I feel like we used social skills because I and my teammates were communicating together during school hours and after school. Self-management, there was some work that I had to do individually so I depended on myself and I did the work myself me and my group collaborated together. Thinking skills, my group and I thought creatively while making the experiment during the hypothesis and the rest of the steps.
  • Sadeem:Social skills, I used my social skills to communicate with my group members. Self Management Skills, I used my time wisely and tried to stay free in case the group members needed me. Thinking skills, I used thinking skills to find some solutions to our problems and to find answers to my questions. Research skills, I researched why lemon juice made the apple turn out how it is, and in the background research step, I also used my researching skills in order to find answers to my questions.
Step 15: Resources
Source #1: How to keep apples from Browning? Here are 6 tricks we love. (2020, June 12). Retrieved from https://www.purewow.com/food/how-to-keep-apples-f...
Source #2: Why do apples turn brown? (2021, January 22). Retrieved from https://miniyummers.com/why-do-apples-turn-brown/...
Source #3: Prakash, S. (2019, September 24). The easiest ways to keep your apples from Browning. Retrieved from https://miniyummers.com/why-do-apples-turn-brown/...
