Apple Ipod Headphone Hack
Intro: Apple Ipod Headphone Hack
Well I know most people on the web has complain about apple ipod touch headphone socket. The reason people complain is that only apple headphones work. In this instructable I will show how to hack a stock apple headphone into a adapter lead. This will let you be able to plug any headphone you like into your apple ipod i touch. As well be able to plug you favorite headphone. I have added a addition socket, so your friend can listen to your music as well. This mod can be apply to any headphone that has a dedicated plug for that device e.g Sony Ericsson Mobile phone or any other device.
STEP 1: Materials and Tools
Materials
1. apple headphone or headphone that work with your ipod
2. two 3.5mm inline stereo sockets $1.25 each from jaycar
Tools
1. sidecutter
2. solder iron
3. multimeter
You can use any socket you like, so if you like the old large headphones use 6.5mm stereo inline socket. I'm unsure how much a apple headphones cost because I got mine for free when I bought my i pod touch second hand :)
Tools
1. sidecutter
2. solder iron
3. multimeter
STEP 2: Putting It Together
1. Cut your apple headphones ear buds off. Now strip the cable to expose the cores inside.
You will need to find which core goes to ground, which goes to L and R channels. These important to maintain the correct stereo sound out of our headphones.
2. First tin the cores with the solder iron, this will make it easy to get a good readings with your multimeter.
3. Set the multimeter to ohms scale. There are four cores in total Green (Left channel), Red (Right channel) and the two grounds: copper, green and red. See picture. To make sure you got the right core place one lead of the multimeter onto the tin core and the other to the plug. Check all cores to the tip and the two rings of the plug. If get it correct the multimeter should read 0.00 ohm or beep. See pic 1 and 2.
Note:
Alternative means of identify L and R channels of your cable.
Cut your earbuds off your cable, then strip the wire that went to your earbuds
As long your earbuds have a L or a R written on them you can use this to identify your
colour cores inside your cable.
4. Now it comes time to merge the tin cores to the socket. Twist the two grounds together and tin these cores together. Solder these two cores to the ground of the socket.
5. Plug your apple plug into your inline socket to find which pin are left and right using your multimeter.
6. Then solder the left and right channel to the stereo socket.
7. Then simply screw on the cover over the terminals.
8. Final and most important step is to check there is no shorts between left and right channels, then left channel to ground and right channel to ground. Using your multimeter on ohm scale. If there is a short it can cause damage to your electronic device.
Note:
STEP 3:
If you want to add that second socket just cut your lead into two pieces. One will have a stereo socket and the other will have the apple plug. Then you follow steps:
1. Tin your cores of your apple cable and your socket cable
2. Twist the four ground cables and two left and right channels
3. Tin the four ground cables and two left and right channels
4. Solder theses cables to that additional socket
5. Then simply screw on the cover over the terminals.
Final and most important step is to check there is no shorts between left and right channels, then left channel to ground and right channel to ground. Using your multimeter on ohm scale. Once you have done that you are ready to try them out.
You can use this cable as an extension cable, as a adapter, or as a means for your friend to listen to your mp3 or apple ipod using the extra socket :)
Hope you like this instructables, please comment and rate.
49 Comments
jasonZak 10 years ago
Beduk 14 years ago
Xixfas 10 years ago
maxpower49 15 years ago
Thekodanator 14 years ago
Landon531 14 years ago
Xixfas 10 years ago
Xixfas 10 years ago
cody777 13 years ago
maxpower49 13 years ago
J@50n 14 years ago
i have a touch my bro had a video my mom has a nano and my mom had a shuffle. they all used different head phones cause apples broke.
cody777 14 years ago
i use skull candy doubleagents with my ipod touch
and they wont work with my iphone 2g
dont ask mne why i have both im sick of being asked that
ibfamous 13 years ago
Xixfas 10 years ago
SasquatchKid 13 years ago
amoreno2 12 years ago
ventifact 13 years ago
