Introduction: Apple Retro Pendrive
Apple itself never released a self-branded USB pendrive, so let fill the gap!
I found a noname USB pendrive in my drawer. It is an old, 128 Mb model, so was easy to sacrifice for this project. Also here is an old apple II keyboard too.
This project right now is in the pocket size contest. If you like it, please VOTE for it!
Thans in advance!
Thans in advance!
Step 1: Tools and Sources
You will need a pendrive, a keyboard,a sharp knife, sandpaper, soldering iron ,a pencil, some glue, scissors
Step 2: Find the Key
Let's see... You have to find a matching key from the keyboard for your naked pendrive! At first I wanted to fit in the "apple" button, but that turned out too short, so give a chance to the "return" button!
Step 3: Fix the Key
The bottom of the buttons aren't even, so you have to flat it with a sandpaper.
Cut out the gap for the USB connector! Use a pencil to mark the size of the connector!
Also, remove those plastic peaks from the key, just to make space for a pendrive inside! I just melt them out with a soldering iron.
Step 4: Check
Quick check, refine, check again...perfect!
Step 5: Make More Apple-ish!
Make it more apple-ish! I removed the tiny apple logo from the keyboard, and glued on the top of the "return" key.
NOTE:To remove a logo, do not try to remove it from the front, because it made of metal, so very easy to scratching down the paint! Take apart the keyboard, and you will find a tiny hole inside, just under the logo. Punched it out through that pinhole with a needle!
Step 6: ...one More Thing...
I had to close the bottom of the key somehow.Firstly I planned to cover it with some kind of rubberized surface to make it anti-grip when remove it from the USB slot.
I always try to make my project as genuine as possible, so why not to use a genuine apple part again?
I removed the apple pro keyboard sticker from the back of it, cut it to the right size, and place it. Hence it is 19 years old still self- adhesive anyway, so saved some glue too! Hmm, 80's Cupertino plastic...
Color match!
Color match!
