Introduction: Application Board of 555 Timer IC
Introduction:
The 555 timer IC is the one of the most useful and well known IC for everyone of us. My professional embedded Hardware carrier start two years back and in 2019 one my resolution is to prepare 45 different circuit using 555 timer IC for understanding the different [suggested By Team Leader :)]. I stated to work on it and by different resource available on internet specially by www.circuitstoday.com , www.circuitstoday.com and Texas Instrument I manged to learn about the 555 Timer IC and Understand the different concept related to time.
In this Instructable I am sharing different Eight application circuit of 555 Timer IC with some new approach. I prepared the Eagle Schematic and Layout Design with keeping the delivery of full understanding of 555 Timer IC with single standalone board.
So in the above design I have included the following circuit with Some information of 555 Timer IC and its Pin Configuration details. Also one 8 contact DIP switch is available to enable individual circuit where the basic information about the each application is available just below the circuit. Also I kept provision of pinhead and wire connector for testing output on different instruments.
Following are the Application circuit available on the Board:
1. Astable Multivibrator
2. Monostable Multivibrator
3. Bistable Multivibrator
4. LED Dimmer using PWM
5. Delay Generator before Turn ON
6. Servo Motor Driver
7. BJT Transistor Testing Circuit
8. Single Digit Counter
I hope all you will like my new approach for these 555 Timer IC Application Board where I always open for the suggestion from all you Techies.
Step 1: 555 Timer IC Board
Above are the Eagle Layout as well as Manufacturing View of 555 Timer Application Board
Step 2: On Board General Basic Information About 555 Timer IC
Above images are the part of design which shows the General information available on the Board. Where the both Manufacturing and Layout view is included in above image.
Step 3: Application No. 1: Astable Multivibrator
Above are the Manufacturing and Layout view of 555 Timer IC as a Astable Multivibrator.
Step 4: Application No. 2: Monosatable Multivibrator
Above are the Manufacturing and Layout view of 555 Timer IC as a Monostable Multivibrator.
Step 5: Application No. 3: Bisatble Multivibrator
Above are the Manufacturing and Layout view of 555 Timer IC as a Bistable Multivibrator.
Step 6: Application No. 4: LED Dimmer Using PWM With 555 Timer IC
Above are the Manufacturing and Layout view of 555 Timer IC as a LED dimmer Using PWM (Pulse Width Modulation) for changing intensity of the targeted LED.
Step 7: Application No. 5: Delay Generator Before Turning on Using 555 Timer IC
Above are the Manufacturing and Layout view of 555 Timer IC as Delay generator before turning On.
Step 8: Appication No. 6: Servo Motor Driver Using 555 Timer IC
Above are the Manufacturing and Layout view of 555 Timer IC as a Servo Motor Driver or testing circuit with controllable direction using switches.
Step 9: Application No. 7: BJT Transitor Testing Circuit Using 555 Timer IC
Above are the Manufacturing and Layout view of 555 Timer IC as a BJT Transistor Testing Circuit with LED indication.
Step 10: Application No. 8: Single Digit Counter Using 555 Timer IC
Above are the Manufacturing and Layout view of 555 Timer IC as a single Digit Timer using Seven segment display and CD4033 counter IC with start button.
Step 11: Conclusion
Above design is the approach to give the Learner or Beginner single solution of 555 Timer IC understanding and Application Use. Also the timing concept understanding in the basic level.
