Introduction: Arch Linux on Raspberry Pi
On this tutorial I will be showing you how I would install Arch Linux on my raspberry Pi. Since there are many different approaches to what could be configured there is no right or wrong way to install this. Thanks
Step 1: Prepare the SD Card and Install Arch Linux
on linux PC:
lsblk
sudo fdisk /dev/sdX
clear partitions on the drive (o)
create first partition (n, p, 1, enter, +100M, t, c)
create second partition (n, p, 2, enter, enter), then write and exit (w)
sudo mkfs.vfat /dev/sdX1
sudo mkfs.ext4 /dev/sdX2
make folder to mount partitions
mkdir /mnt/boot/
mkdir /mnt/root/
sudo mount /dev/sdx1 /mnt/boot/
sudo mount /dev/sdx2 /mnt/root/
download and install arch
wget http://archlinuxarm.org/os/ArchLinuxARM-rpi-2-latest.tar.gz
sudo su
tar zxvf /location/of/file/ArchLinuxARM-rpi-2-latest.tar.gz -C /mnt/root
mv /mnt/root/boot/* /mnt/boot
sync
Step 2: Init
On Raspberry Pi:
login: root
password: root
setting up wifi with wpa_supplicant
sudo nano /etc/wpa_supplicant/home_wifi
add following and edit ssid and psk with your old network info
network={ ssid=”neworkname” psk=”password” }
initiating pacman, upgrading arch and install sudo
pacman-key –init
pacman -Syu
pacman -S sudo screen
nano /etc/sudoers.d/myOverrides
add following
alarm ALL=NOPASSWD: ALL
switch to user alarm:
su alarm
Step 3: Installing Desktop
install packer for additional software down the road
sudo pacman -S packer
now lets install the desktop
sudo pacman -S xorg-server xf86-video-fbdev xorg-xrefresh
leave everything as default
XFCE4:
sudo pacman -S xfce4 xfce4-goodies
now we need desktop manager:
sudo pacman -S sddm
we are going to load default configs with this command
sudo sh -c “sddm –example-config > /etc/sddm.conf”
autologin:
sudo nano /etc/sddm.conf
search and modify:
[autologin] Session=xfce.desktop User=alarm
custom theme i’m using
packer -S arc-gtk-theme
custom fonts
packer -S ttf-roboto
SDDM autostart:
sudo systemctl enable sddm
sudo systemctl start sddm
Step 4: Network Manager
lets install a network manager so you can control your wifi or ethernet via gui
sudo pacman -Syu networkmanager network-manager-applet
sudo systemctl enable NetworkManager
sudo systemctl start NetworkManager
reboot
Step 5: Bluetooth
lets install the tools we need to compile bluetooth
sudo pacman -S make gcc git-core automake autoconf pkg-config libtool patch
packer -S yaourt blueman
yaourt -S pi-bluetooth
sudo systemctl start bluetooth.service
sudo systemctl enable bluetooth.service
sudo systemctl enable brcm43438.service
sudo pacman -Syu pulseaudio-alsa pulseaudio-bluetooth pavucontrol bluez bluez-libs bluez-utils bluez-firmware
11 Discussions
5 days ago
6 days ago
It's `sddm --example-config | sudo tee /etc/sddm.conf` and not `-example-config`, but it's better to get users used to tee instead of rogue sh lines :)
3 months ago
is it me or ? but I'm a complet noob, so sorry if I'm wrong
This gives me an error and am stuck here
also I had to sudo to get these two to work
mkdir /mnt/boot/
mkdir /mnt/root/
3 months ago
The problem here is that ARCH Linux | ARM and Archlinux now recommends a partition size of +200M not +100.
If you're not willing to update this tutorial I suggest you delete it.
https://archlinuxarm.org/platforms/armv8/broadcom/raspberry-pi-4
9 months ago
Actually a nice guide and it would be even nicer if systemD would never come to existence.
Yeah thats one thing the the double -- dashes did not get properly registered on the side and when you copy them back to the terminal they become single - and break things but man the amount of trouble systemD gave me just made me chose another distro.
So here is what happens after install:
1, wireless will not connect out of the box even after you set the supplicant you will need to run wpa_supplicant ...
2, Even after you connect you will not get an IP you will need to run dhclient wlan0
Now this is where potterD gonna mess with you: you will notice that the DNS is not working hmmm why? it is because systemd does not care about /etc/resolv.conf it has hardcoded DNS servers such as 1.1.1.1 which is some DNS server from australia... anyway still the DNS servers are online so they should work so what is going on?
What is going on is that DNS sec is enabled by default and it relies on computer time but your time is way off thanks to systemd and NTP is not installed.
This was the point where I got fed up.
Question 11 months ago on Step 5
im not able to boot to GUI
11 months ago
Hi Can anyone advise me, i setup the arch linux arm for raspberry pi 4 but somehow it does not goes to the GUI screen or how shall i go about it dun seems to work for me
1 year ago on Step 3
This step broke the installation. Going by your instructions.
1 year ago on Step 2
pacman-key --init
pacman-key --populate
Notice the extra step necessary and that you put a single - instead of --
This would have stopped anyone else right there as soon as they tried. And without populating the keys you'd never be able to update.
1 year ago
It did not for me using an usb stick. Maybe gottta try the sd card they delivered with it.
For me it booted but didn't load shit, so it got me into a emergency shell of no return
1 year ago
custom theme
pacmac -S arc-gtk-theme
custom fonts
