Introduction: Arduino 4WD Car
This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (www.makecourse.com).
This is an Arduino project using knowledge of Computer Aided design (CAD) softwares like Solidworks, Autodesk Fusion 360, C++ programming knowledge and basic circuit connections
Step 1: Mechanical Components
The first step in making this project is to design the mechanical component. I used Autodesk Fusion 360 which is compatible with MAC OS. The parts were tricky, basic concept of CAD knowledge.
Step 2: Arduino Sketch
Attached is the arduino sketch, a better explanation is in the attached the video.
Step 3: Building Process
Parts:
1. Arduino Uno
2. Breadboard
3. Jumper Cables
4. Arduino HC-06 Bluetooth shield
5. DC H Bridge Module
6. Motors
7. Screws
Tools
1. Soldering kit
2. Screw drivers
3. Wire cutter
Step 1: Soldering
Attach the red and black wires to the motors and solder them. This should be in sync with the rest of the motors,to make connection easier later on.
Step 2: Coupling
Couple the body parts together
Step 3: Electric Wiring
The electric components should follow the image attached
Pin Description
Motors Connection:
Out1 -> Left Side Motor Red Wire (+ )
Out2 -> Left Side Motor Black Wire ( - )
Out3 -> Right Side Motor Red Wire ( + )
Out4 -> Right Side Motor Black Wire ( - )
LM298 - > Arduino
IN1 -> D5
IN2-> D6
IN2 ->D9
IN2-> D10
Bluetooth Module -> Arduino
Rx-> Tx
Tx ->Rx
GND -> GND
Vcc -> 3.3V
Power
12V - > Connect Battery Red Wire
GND -> Connect Battery Black wire and Arduino GND pin
5V -> Connect to Arduino 5V pin
Step 4: Using Arduino.cc
Upload the code
Step 5: Test
Pair the HC-06 Module with an Android phone
Preferable: "Arduino Car Control" App from Google Playstore
Step 4: Project Preview
