Arduino 4WD Rover Bluetooth Controlled by Android Phone/tablet
Intro: Arduino 4WD Rover Bluetooth Controlled by Android Phone/tablet
This is a simple 4WD rover i made with Arduino.
the rover is controlled with an android phone or tablet over bluetooth. With that app you can control speed (using Arduino's pwm) , run it with the accelerometer and many other things.
The Arduino sketch is fully commented and open source, also the communication protocol (developed by me) from the app to Arduino is explained in the sketch .
Knowing the protocol you can use the app to control other robots...
STEP 1: What You Need...
In order to build your own Arduino 4wd rover you should buy all the needed parts from your preferred store.
Most of them can be bought on ebay or amazon or other online electronics/hobby stores.
I try put some links but they could be outdated and not working, in this case try search the part manually by name. Sorry for that.
Anyway it’s a very simple robot kit usually made by a chassis, four Dc (up to 12V) motors with gearmotor and four wheel.
The parts used are:
- 1 pcs of chassis complete with 4 DC motors, usually called Arduino rover 4wd, for example these:
http://www.robotik.center/index.php?route=product/... from http://www.robotik.center/
http://www.robotshop.com/en/dagu-4wd-chassis.html
http://www.robotshop.com/en/whippersnapper-runt-ro...
http://www.robotshop.com/en/juniorrunt-rover-kit.h...
Also a search on Ebay with the '4WD chassis robot arduino' keywords will return a lot of results.
- 1 pcs of Arduino uno R3 or Arduino Leonardo board.
- 1 pcs of Bluetooth module HC-05 or HC-06 with adapter board (Updated! 2017 , October 10, now supports HC-05 module for whose of you that already have it)
- 1 pcs L298 bridge dual motor controller board.
There are many different of these but the pinout is 99% the same for all.
Just connect wires to the right pins based on the board diagram. with this tutorial you can find the datasheet of the one I used (see next step).
- 3 pcs 3.7V 1200mA (or more) Li-Ion rechargeable battery AA size or 11,1V 1200mA LiPo battery pack.
if you use the AA size battery you can put them in a battery holder.
- 1 pcs Jack plug for Arduino power plug.
- 1 pcs 1Kohm resistor.
STEP 2: The Schematic Diagram...
This is the schematic diagram for wiring the rover, please follow it while assembling it in the next step...
The L298 pdf will help you in case you have a different board pinout.
The HC-05 and HC-06 bt modules have the same pinout.
Sometimes the HC-05 has 6 pins instead of 4, check pins name on the bottom of the module to be sure to use correct pins.
STEP 3: Assembling the Rover…
Follow the numbered images and the short video for the assembling order (some things may differ depending on your chassis…).
- Start with the motors on the chassis and wheels (image 1).
- Mount the L298 motor controller board and wire motors to it.
Also add 2 wires to power the board (image 2 and 3). - A piece of flat cable will connect the board to Arduino, you need only 6 wires but I left some other free for future use (maybe lights or ultrasonic sensor…).
Also wire the jack plug , pay attention to polarity, the central pin is positive (+11.1V from battery) (image 4). - Place the battery holder (or the battery pack) in the front of the rover, fix it with a piece of double-sided tape. If you choose the AA size battery it’s simple to remove them individually for recharging.
If you choose a battery pack then could be a good idea to put a connector between the battery pack and the rover (image 5). Place the top of the rover…the flat cable and the jack plug passes through the hole (image 6)
Assemble the bluetooth module with the resistor using a piece of flat cable (usually provided with the module). Cut the RXD wire (not the pin!) and solder the resistor in series to the wire.
Seal with a heat-shrinkable tube (image 7).Place the Arduino board and the module. Connect the flat cable as in the schematic.
Fix the Bluetooth module with a (very) little piece of double-sided tape.
Connect the power jack to Arduino (image 8).
STEP 4: The Arduino Sketch...
Connect only the Bluetooth module HC-05 or HC-06 to Arduino as in the schematic (remember the 1Kohm resistor! on RXD pin of the module).
Open the Arduino sketch, uncomment the correct #define for your bluetooth module and be sure to comment the other one, see image. Upload it to an Arduino uno R3 or Leonardo Board, let the USB cable connected so the board remains powered.
1) Open the serial monitor and set the communication speed to 115200 baud and the NL (New Line) terminator.
In the serial monitor write the string: ‘Echo on’ and click Send, you should see ‘Echo is on’, this will echoes the next commands to the screen. Now write the string: ‘Device’ and click Send, you should see ‘Connected to: ArduinoRover’
Now follow the steps below to test the bluetooth connection depending on the module you chose. Note: when you send AT commands to the bluetooth module be sure commands are uppercase!
2a) Test for HC-06 module
Don't power off Arduino (if you did it, restart from point 1, you need the Echo on) and send the string ‘AT’ , you should see ‘HC-06> OK’ after about one second, this mean your Bluetooth module is correctly connected and the baud rate match the one set in the sketch at line: BtSerial.begin(9600).
To change the Bluetooth module name send the string ‘AT+NAMEArduino’ (for example), you should see 'HC-06> OKsetname' in about a second.
Now try to find the Bluetooth module with your smartphone or tablet and pair with it, insert the pin, usually 1234 when asked for.
2b) Test for HC-05 module
This bluetooth module is a bit tricky, so follow exactly the instructions and see the image with the screenshot from the IDE.
Power off Arduino by removing the USB cable.
There is a little pushbutton on the HC-05, see images, keep it pressed while reconnect the USB cable to power on Arduino and until the red led on the module starts flashing slowly.
This is a special command mode to be sure to match the BtSerial.begin(38400) speed in the sketch.
Now open the serial monitor as per point 1, enter 'Echo on' and click Send, you should see 'Echo is on'.
Send the string 'AT' , you should see 'HC-05> OK'.
Send the string 'AT+ORGL' , the module will respond 'HC-05> OK' , this resets the module to factory default parameters.
Send the string 'AT+UART?' , you should see 'HC-05> +UART:38400,0,0' this is the default communication speed.
Send the string 'AT+PSWD?' , you should see 'HC-05> +PSWD1234' this is the default password 1234.
Send the string 'AT+NAME=HC-05_rover' (for example, just use your preferred name after the sign=), it should respond with 'HC-05> OK' .
Now power off Arduino by removing the USB cable and power on again after a few seconds.
Try to find the Bluetooth module with your smartphone or tablet and pair with it, insert the pin you got in serial monitor, 1234, when asked for.
3) Complete the project (see assembling the rover) if not already done.
STEP 5: The Android App...
Now your Rover is ready to run!
You need the FREE android app IRacer & Arduino BT controller from the playstore here:
https://play.google.com/store/apps/details?id=com....
The app allow you to drive the rover with the four way joystick in portrait mode or with 2 joystick (multitouch) in landscape mode.
Be sure to choose the correct device in the app: Open the app menu (the 3 lines button),open the app settings (the gear) -> Remote control setup -> click and select the device to drive: Arduino Rover.
From the menu, choose connect and select your already paired bluetooth module name from the list to connect to.
In the settings menu there are a lot of options (backgrounds, speed limits ...) to play with, enjoy :)
54 Comments
Baasil Biniyamin 6 years ago
I just made one, bluetooth module and the rest were successfully done but the rover is not moving.....i dont know whats happening the code was successfully uploaded.
AppsByDavideV 6 years ago
Hello, did you manage to connect correctly?
You should see something like the image below, check the red box in the image.
If the connection is good then the problem could be in the motor driver controller or connections between Arduino and the driver. Check also to have enough power from the battery (i recommend a battery pack >10V and 1500mA)
Be sure to choose the correct device in the app: open the app settings -> Remote control setup -> click and select the device to drive: Arduino Rover
You can also post a detailed pics of your work, specially the driver and connections
EmilS32 6 years ago
bro please reply
Hi EmilS32,
it seems an error of the IDE, maybe a missing driver/bad installation.
Try install the IDE again. Your problem is not related to the project.
I suggest you to try search on the Arduino forum if the reinstallation of the IDE doesn't fix the problem.
EmilS32 6 years ago
go to the settings menu of the app. there are 2 switches to change the direction of the sliders.
don't forget to click on IMade it! under the title above... thanks!
EmilS32 6 years ago
BRO it shows following errors
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 8122 bytes (25%) of program storage space. Maximum is 32256 bytes.
Global variables use 543 bytes (26%) of dynamic memory, leaving 1505 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x76
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
EmilS32 6 years ago
Send me some detailed images of the board with the driver
EmilS32 6 years ago
Hi,
please provide a link or schematic of your L298N board/shield so i can try to help
Tdhankot 6 years ago
Hi, it compiles correctly for me using the windows version of the Arduino IDE V1.8.1 and arduino nano.
Don't know about ArduinoDroid.
Why don't you use the arduino ide instead?
Uses of undeclared identifier 'setmotor'
Uses of undeclared identifier ' getreceivedbytes'
'btserialprint'
Uses of undeclared identifier 'readusbuffer'
Uses of undeclared identifier 'usbechomode'
Uses of undeclared identifier 'serialprint'
Uses of undeclared identifier 'usbsendatmode'
How to solve this please tell me
Yes , it is the same as Leonardo that i already test. Carefully check the pinout to match the schematic.
sorry, i'm wrong. it is the same as UNO so it will work anyway. Again, check carefully the pinout
RIJULT 6 years ago
I got a L293d shield. Will it work?
Hi Rijult,
sorry for the late reply.
I think it will work but you need to adjust code to match this shield. Carefully check/compare your shield's pinout with the one used in the project. Also (probably) you need only 1/2 of your shield for this project.
Bye
