Introduction: Arduino 7 Segment (5011BS, Common Anode or Cathode) Tutorial
We are going to make this thing work! Common cathode or Anode.
Step 1: Connect That Sucker.
Step 2: Connect Pins 3 & 8 to Power (common Anode) or Ground (common Cathode)
Use a 330 resistor, 1k makes the led's too dim. Scream 'power' in the vein of Clarkson while completing this step. (Important)
Pins 3 and 8 are the center pins top and bottom.
Step 3: Flash the Arduino for Calibration.
Download the Seven Segment library and install to the Arduino IDE.
https://github.com/DeanIsMe/SevSeg/archive/master....
To install it, open the Arduino IDE, go to Sketch > Include Library > Add .ZIP Library, then select the SevSeg ZIP file that you downloaded.
Now we need to flash the Arduino to print the number 8 with a dot so that we can connect her up.
code:
#include "SevSeg.h"
SevSeg sevseg;void setup(){ byte numDigits = 1; //we are using a single digit display byte digitPins[] = {}; //leave empty for a single digit display byte segmentPins[] = {1, 2, 3, 4, 5, 6, 7, 8}; //choose any 8 pins bool resistorsOnSegments = true; byte hardwareConfig = COMMON_ANODE; sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments); }
void loop(){ sevseg.setNumber(8, 0); //Print 8, 0 means Decimal point is active, 1 turns it off. sevseg.refreshDisplay(); //Needed to continue displaying the number }
Step 4: Now Let's Start Calibrating. (Segment A, Arduino Pin 1, LED Pin 7)
Now, we are going to calibrate from A-DC in order, one by one.
Look at this code, it's alphabetical from A-DC.
We are telling the Arduino that:
pin1 = A,
pin2 = B,
pin3 = C
pin8 = DC.
So now, connect segment A to pin 1. (pin 7 on the LED )
Step 5: Connect Segment B (Arduino Pin 2, LED Pin 6)
Step 6: Connect Segment C (Arduino Pin 3, LED Pin 4)
Step 7: Connect Segment D (Arduino Pin 4, LED Pin 2)
Step 8: Connect Segment E (Arduino Pin 5, LED Pin 1)
Step 9: Connect Segment F (Arduino Pin 6, LED Pin 9)
Step 10: Connect Segment G (Arduino Pin 7, LED Pin 10)
Step 11: Connect Segment DC (Arduino Pin 8, LED Pin 5)
Step 12: Tidy Up and Say, 'cleanliness Is Next to Godliness' and Smile Because Your 8 Is Looking Sexy As Heck.
Step 13: Make a Counter to Show Off Your Technical Prowess.
Copy & paste like it's hot, we are just tweaking the main loop.
void loop(){
for (int i = 0; i<10; i++){ sevseg.setNumber(i, 0); sevseg.refreshDisplay(); //Needed to continue displaying the number delay(1000); } }
