Introduction: Arduino 7 Segment Display
Hello, and welcome to this tutorial on how to light a seven segment display! This will be without code, so you don't have to know C++ to do this.
• 220Ω Resistor
• Breadboard
• Arduino Uno Rev3
• 7 Segment Display
• 10 Male to Male Jumper Wires
Step 1: Assembly
• First, place your 7 segment display on the breadboard.
• Next, take 8 jumper wires and connect the LED pins to the negative rail.
• Then, take your resistor and connect either common (middle) pin to the positive rail.
• Finally, take the other 2 jumper wires and connect a ground to the positive either the 3.3V or the 5V to the negative rail. Flip the two if you are using a common anode.
Step 2: Done!
Power up your Arduino and you're done! Thanks for reading!
