Introduction: Arduino Bargraph Display
In Embedded system design, bar graph display is used for representing the signal strength, status indication, error indication in grouped or progressive indication of system parameters
Step 1: Parts and Components
- Arduino Uno board
- 330 Ohm resistor = 10 Nos
- Bargrpah display
- 1 K ohm potentiometer
Step 2: Schematic
- The bargraph display is connected to the Arduino (2,3,4,5,6,7,8,9,10,11) digital IO pins through 330 ohm current limiting resistors.
- The potentiometer is connected to the Arduino ADC (A0) pin for simulating the signal strength.
- The potential read by the 10 bit ADC, (1024 steps ) is mapped to 0 to 10 scale and correspondingly activating the LED’s at the Bargraph display in increasing order.
- Real life scenario, the signal strength is read by the ADC, accordingly bargraph is activated for visual representation.
Step 3: Software
LED bar graph
Turns on a series of LEDs based on the value of an analog sensor.
This is a simple way to make a bar graph display. Though this graph
uses 10 LEDs, you can use any number by changing the LED count
and the pins in the array.
This method can be used to control any series of digital outputs that
depends on an analog input.
The circuit:
* LEDs from pins 2 through 11 to ground
created 4 Sep 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BarGraph
// these constants won't change:
const int analogPin = A0; // the pin that the potentiometer is attached to
const int ledCount = 10; // the number of LEDs in the bar graph
int ledPins[] = {
2, 3, 4, 5, 6, 7, 8, 9, 10, 11
}; // an array of pin numbers to which LEDs are attached
void setup() {
// loop over the pin array and set them all to output:
for (int thisLed = 0; thisLed < ledCount; thisLed++) {
pinMode(ledPins[thisLed], OUTPUT);
void loop() {
// read the potentiometer:
int sensorReading = analogRead(analogPin);
// map the result to a range from 0 to the number of LEDs:
int ledLevel = map(sensorReading, 0, 1023, 0, ledCount);
// loop over the LED array:
// if the array element's index is less than ledLevel,
// turn the pin for this element on:
if (thisLed < ledLevel) {
digitalWrite(ledPins[thisLed], HIGH);
// turn off all pins higher than the ledLevel:
else {
digitalWrite(ledPins[thisLed], LOW);
