Introduction: Arduino Based 12V PWM Generator
12VDC is an important power source in cars. As a matter of fact, many automotive components like radiator fans, water pumps, valves and small motors can be controlled in a stand-alone fashion with a supply of 12VDC power and 12V PWM control signal, besides the LIN/CAN protocol. If you want to test an automotive part on your bench before putting it into your car, you would probably need a 12V PWM signal and this project will teach you how to generate a 12V PWM signal using Arduino.
- LM339 x1
- Arduino Uno x1
- 2.7K/0.25W Resistor x2
- 1K/0.25W Resistor x1
- Jump wires
- Breadboard x1
- 12VDC power supply x1
Step 1:
There are four short steps only:
- Prepare your parts according to the BOM;
- Wire up your circuit according to the diagram provided;
- Program your Arduino - the code is provided at the end of the post ;
- Test your setup.
I'm including my setup and 12V PWM signal output on oscilloscope for your reference. I hope everyone finds this tutorial useful and enjoys what you do.
Best,
JT_Enliten
Arduino Code:
#include <PWM.h>
const int PWM_pin = 9;
void setup() {
pinMode(PWM_pin,OUTPUT);
InitTimersSafe();
bool success = SetPinFrequencySafe(PWM_pin, 60);//frequency
pwmWrite(PWM_pin, 128);//duty cycle
void loop() {
