Introduction: Arduino Bathroom Scale With 50 Kg Load Cells and HX711 Amplifier
This Instructable describes how to make a weighing scale using readily available off the shelf parts.
Materials needed:
- Arduino - (this design uses a standard Arduino Uno, other Arduino versions or clones should work also)
- HX711 on breakout board - This microchip is specially made for amplifying the signals from load cells and reporting them to another mircocontroller. The load cells plug into this board, and this board tells the Arduino what the load cells measure.
- 50kg load cells (x4) - Load cells are specially shaped metal parts that have strain gauges glue to them. The strain gauges are resistors that change their resitance when they are bent. When the metal part bends, the resistance of the load cell changes (the HX711 measures this small change in resistance accurately). You can buy the load cells and HX711 as a kit here: https://www.amazon.com/Degraw-amplifier-weight-Arduino-Bathroom/dp/B075Y5R7T7/ If you do purchase the kit please leave a review! It is really helpful for future buyers.
- Sturdy flat mounting surface - a stiff piece of hardwood or metal is ideal
- Wires in various colors for connecting all the parts
- Power supply for Arduino
Step 1: Mount the Load Cells
Mount the 4 load cells to the bottom of the scale in the four corners. Epoxy works well to hold them in place. See the mounting diagram, it shows which surface should be mounted to the base and which surface should touch the floor.
Step 2: Verify the Load Cell Wiring
The wiring diagram is made assuming the load cell is constructed like this picture.
To make sure you get it right, be sure to figure out which two terminals on the load cells have the highest resistance between them (E.g. Black and White, to match the schematic), wire them in a big color matching loop, like B-B W-W B-B W-W and then excite (E+/E-) two opposite center taps (R) and sense (A+/A-) on the other pair of center taps.
This page on Sackexchange has even better information: https://arduino.stackexchange.com/questions/11946/how-to-get-weight-data-from-glass-electronic-bathroom-scale-sensors/18698#18698
Step 3: Wire the Load Cells and HX711
See the wiring diagram for how to connect the load cells, HX711, and Arduino.
Some of the load cell wires are connected together to form what is called a Wheatstone bridge arrangement. This can get a little confusing. A good option for connecting all the load cells in a clean, easy to understand way is the SparkFun load cell combinator board - https://www.sparkfun.com/products/13878
This arrangement allows the loads on all of the different load cell sensors to be combined and measured at once.
Step 4: Add HX711 Library to Your Arduino IDE
The HX711 library is available here: https://github.com/bogde/HX711
See this link on the Arduino website for instructions on how to add the library to your Arduino IDE: https://www.arduino.cc/en/Guide/Libraries
Step 5: Calibrate and Weigh!
Sparkfun has great Arduino programs to run the scale. The most up to date versions are available on GitHub and reprinted below: https://github.com/sparkfun/HX711-Load-Cell-Amplifier
The first software step is to determine calibration factors for the scale. To do this, run this code:
Example using the SparkFun HX711 breakout board with a scale
By: Nathan Seidle
SparkFun Electronics
Date: November 19th, 2014
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
This is the calibration sketch. Use it to determine the calibration_factor that the main example uses. It also
outputs the zero_factor useful for projects that have a permanent mass on the scale in between power cycles.
Setup your scale and start the sketch WITHOUT a weight on the scale
Once readings are displayed place the weight on the scale
Press +/- or a/z to adjust the calibration_factor until the output readings match the known weight
Use this calibration_factor on the example sketch
This example assumes pounds (lbs). If you prefer kilograms, change the Serial.print(" lbs"); line to kg. The
calibration factor will be significantly different but it will be linearly related to lbs (1 lbs = 0.453592 kg).
Your calibration factor may be very positive or very negative. It all depends on the setup of your scale system
and the direction the sensors deflect from zero state
This example code uses bogde's excellent library:"https://github.com/bogde/HX711"
bogde's library is released under a GNU GENERAL PUBLIC LICENSE
Arduino pin 2 -> HX711 CLK
3 -> DOUT
5V -> VCC
GND -> GND
Most any pin on the Arduino Uno will be compatible with DOUT/CLK.
The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power should be fine.
#include "HX711.h"
#define LOADCELL_DOUT_PIN 3
#define LOADCELL_SCK_PIN 2
HX711 scale;
float calibration_factor = -7050; //-7050 worked for my 440lb max scale setup
void setup() {
Serial.begin(9600);
Serial.println("HX711 calibration sketch");
Serial.println("Remove all weight from scale");
Serial.println("After readings begin, place known weight on scale");
Serial.println("Press + or a to increase calibration factor");
Serial.println("Press - or z to decrease calibration factor");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale();
scale.tare(); //Reset the scale to 0
long zero_factor = scale.read_average(); //Get a baseline reading
Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
Serial.println(zero_factor);
void loop() {
scale.set_scale(calibration_factor); //Adjust to this calibration factor
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1);
Serial.print(" lbs"); //Change this to kg and re-adjust the calibration factor if you follow SI units like a sane person
Serial.print(" calibration_factor: ");
Serial.print(calibration_factor);
Serial.println();
if(Serial.available())
char temp = Serial.read();
if(temp == '+' || temp == 'a')
calibration_factor += 10;
else if(temp == '-' || temp == 'z')
calibration_factor -= 10;
}After calibrating the scale, you can run this sample program, then hack it up for your own purposes:
By: Nathan Seidle
This example demonstrates basic scale output. See the calibration sketch to get the calibration_factor for your
specific load cell setup.
The HX711 does one thing well: read load cells. The breakout board is compatible with any wheat-stone bridge
based load cell which should allow a user to measure everything from a few grams to tens of tons.
3 -> DAT
5V -> VCC
GND -> GND
#include "HX711.h"
#define calibration_factor -7050.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
HX711 scale;
void setup() {
Serial.begin(9600);
Serial.println("HX711 scale demo");
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
void loop() {
Serial.print(scale.get_units(), 1); //scale.get_units() returns a float
Serial.print(" lbs"); //You can change this to kg but you'll need to refactor the calibration_factor
Serial.println();
