Introduction: Arduino Beautiful Night Light
My product is the Arduino LED Night Light. About my project, I used transparent cap to make LED look nicer.
I follow the link the website for reference.
Step 1: Materials
-LED- x1
-Jumper Wire- x3
-Resistor- x1
-Scissors- x1
-USB cable- x1
-Arduino Leonardo- x1
-Breadboard- x1
-Glass cap- x1
-Shoes box- x1
Step 2: Circuit Connection
1. Put the LED on the breadboard.
2. Connect the Jumper Wire from the same line as long leg to your output
3. Connect the resistor from the same line as the short leg to B-48
4. Connect another jumper wire from the same line as the resistor to the negative of the breadboard
5. Connect the final jumper wire from the negative of the breadboard to the GND
Step 3: Programming
To upload the code into Arduino, you'll need to attach your Arduino broad with pc using the USB cable
This link is for the code that I used: https://create.arduino.cc/editor/asiachenhello/1ba9d0d9-c8d0-4b13-b5bb-ab1538dd2511/preview
Step 4: Making Exterior
1. Take a box and cut a small hole for LED to cross through.
2. Put your transparent cap on the LED/
Step 5: !Done!
After you upload the code into Arduino, you can connect the USB cable to the power bank for the look.
