Introduction: Arduino Bluetooth Car Control
Arduino - Bluetooth Car Control
Project Application steps:
1. Install “Arduino Bluetooth Car Control” Application from below link:
https://play.google.com/store/apps/details?id=com....
Download Connection schemmatic, insallation steps .and Arduino .ino code from link:
https://drive.google.com/drive/u/0/folders/0B8lboyisdqhBU0EtdEl3RExGdmc
3. Connect your devices. (It's explain at below)
4. Download Arduino .ino code to your Arduino Uno card.
That's all.(It takes just one hour.)
Youtube Link:
Enjoy.
(Also you can make some different applications by change Arduino.ino code.)
Components :
- 1 X Arduino Uno
- 2 x DC motors. (Steering motor and Forward/Reverse Motor)
- 1 X L298 Motor Motor Driver Card.
- 1 X Bluetooth Module (HC-05, HC-06 ect.)
-1 X Batar yor Powerbank ( 9- 12 volt) (You can choose this according to your car's power )
- 4 X LEDs
- 1 X Buzzer
- 2 X 1kΩ Resistors
- 2 X 220Ω Resistors
- 1 X On/Off Switch
- Wires.
Step 1:
Arduino - Bluetooth Car Control installation steps:
Take a toy car case with the above chassis structure.
Step 2:
We build the above device.
Make a plan for components layout .
Step 3:
Soldering Motor wires and connect the wires to Motor Driver.
Step 4:
Connect the Arduino - Motor Driver - Bluetooth.
Step 5:
Soldering LEDs and 220Ω resistor and buzzer..
Connect the Arduino - On / Off switch – Buzzer –LED’s.
Step 6:
We connect the On / Off switch to the cable connected to the positive (+) terminal of our battery (9 -12 Volt).
We connect the minus (-) end to the ground of the device. If you want, we can close the upper cabin and screw it.
That’s All.
The mechanical assembly is finished.
