Arduino Controlled LED Strip Holiday Lighting
125,262
91
11
Introduction: Arduino Controlled LED Strip Holiday Lighting
About: A Maker since childhood with all the classic symptoms, a robot builder, and an Internet software CTO/Tech Product Manager.
With the prices dropping on LED strip lighting, setting up Permanent Holiday Lighting is getting more feasible every day.  An Arduino makes a great DIY lighting controller.
For this project, I used some analog RGB LED Strips with a very simple Arduino control setup so we can make our own light show!  I used two strips that were run next to each other, so there are six LED lines to control - two sets of R,G,B.  The analog strips allow you to control each color for the whole strip so you can dim and brighten colors on the whole strip.  Digital LED strips offer individual LED control so you can do chase effects, but they cost a lot more.
The setup for this is the same as was used for the TeleToyland Sandbox 2 project LEDs, except you can control those live!
Controlling the relatively high current LED strips from an Arduino takes some extra components, but the cool thing with MOSFET transistors is that they are very easy to use.  No extra components like resistors are needed, so the wiring is easier.
Step 1: Parts
The following parts were used for this project.  I added links for most of the places I found them (OK, I'm an Amazon Prime addict), but most of the parts are widely available, and Adafruit has most of them.
  • Waterproof LED Strips.  Be sure to look carefully at the types of LEDs used.  I ordered ones using the 3528 LEDs on Amazon and those are the ones pictured here.  These are lower cost, but have a very important disadvantage!  They have separate red, green, and blue LEDs about 1/2" apart, so you cannot get truly blended colors like yellow or orange with direct viewing (unless maybe you are REALLY far away!).  So, they would not be good for permanent lighting.  But, since I am using them for Christmas, they work OK - each of the separate colors is a valid holiday color, and when you turn on red and green at the same time, they alternate nicely.  The 5050 LEDs are tri-color, and thus can have any apparent color output.  The other thing to note is that some strips have 150 LEDs per 5m (16 feet), and some have 300.  They all work pretty well, and the 300 LEDs take more power.
    This one uses 5050 LEDs and comes with a power supply, receiver and remote control.  The power supply is useful for this project, but we will not need the receiver and remote.  They are nice for initial testing, though.
  • Arduino - most of them will be fine for this application.  I used an Arduino Uno I had available.
  • An Arduino prototyping shield - I used a spare MakerShield that I had, but any of them should be fine.
  • (6) N-Channel Power MOSFET transistors from Adafruit - you need one per color.  Since I had two strips with R, G, B on each, I needed 6 of them.  There are other ways to do this, but the nice thing about the MOSFETs is there are no other components needed.
  • 12v supply and connector - check the current needed for your LED strips - they typically draw several amps.  I had a power supply from an LED kit, which can handle about 4 amps, and seems to work with the two strips I have.  For the connector, I used a pre-wired jack from Jameco.  The 12v power supplies have different connectors, so make sure your jack matches the power supply plug.
  • (2) LED strip connectors - See step 2 - female ones with the below adapters are the most flexible.  You could use other connectors, or even hard wire them.  You can also get clip on connectors.
  • (2) male-to-male adapters if needed by your particular LED strips.
  • Wire staples - 1/2" NM type like these.  I got a bunch at Home Depot.  These are slightly bigger than the waterproof LED strips, so they don't pinch the strips.  In my case, I will remove the strips after the holidays, so these work well.
Step 2: Wiring and Programming
Wiring
Adafruit has a great tutorial on how to use an Arduino to control these analog strip lights.  The circuit here is exactly what is in the tutorial (times two).  The nice thing about needing 6 LED lines is that the basic Arduino boards have 6 pins that allow the PWM out - 3, 5, 6, and 9, 10, 11.  So that works out perfectly for two strips!
You can see from the pictures how the FETs were mounted.  The source pins were just soldered together and connected to the Ground (-) side of the power supply since the LEDs are common anode (+).
The only other trick here is that I used the 12 volt supply to run the Arduino too, by connecting it to the Gnd and Vin pins.
Make sure you have the right jack for your power supply.  I have a 2.1mm ID power supply, but was testing it with a 2.3mm one, and it was not making a good electric connection.  Very pesky.
There are a few ways to connect the LED strips to the circuit:  Using the standard LED strip 4-pin inline connectors, using your own connectors, and direct soldering to the strips.  They all will work fine, so you can choose your own approach.  Having some kind of connectors is probably better to make it easier to take apart.  I used the standard LED connectors.  So, for that approach, you will need some extra connectors for the circuit side.  I found some on Amazon, and I chose female ones.  The LED strips seem to have a random choice between male and female connectors, but the trick with using female connectors on the circuit side is that you can also get male-to-male adapters to handle the specific configuration of the LED strips.
I used some four conductor wire to extend those connectors a bit to make it easier to move the Arduino around.
Programming
A sample Arduino sketch is attached, and is very simple.  I started with the sample from the Adafruit tutorial and made some changes.  I am still trying different animation techniques - one tip so far is that in a doorway type situation like mine, keeping at least one strip partially on most of the time is better.  Maybe we can start a library of best holiday scripts.
Since the MakerShield has a potentiometer, you could use that to set the timing constant in the code very easily.
Step 3: Boxing It Up and Mounting the LED Strips
I used a simple plastic container to protect the Arduino.  I intend to dress it up more or hide it better shortly!  Once the Arduino is programmed, connecting it is easy since there are just the three connectors to plug in.
For the LED strip mounting, the 1/2" NM staples worked well for me, but there are plenty of other approaches.  I do not think I would trust the adhesive strip, though that may work.  In my case, I will slip those strips out after the Christmas holidays since they have the separate color LEDs (see the parts list).
Make It Glow
Make It Glow
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
    11 Comments
    progmpg
    progmpg
    6 years ago
    Hi,
    So I just received a 5m 150 led 5050 rgb strip. There is no spec included with the strip, but the item title on the page where I purchased it said it was 12vdc.
    I have been digging for circuits based on mosfets because thats what I have to use. So thank you for about the resisters. The mosfets I have are NTE 2985 60V 30amp TO220 package.
    I now have to find a power supply. Should I go 12vdc or less, maybe 9vdc? In all the reading I have done it appears I need a 5 amp supply, thats 60W or 45W. This seems excessive to me but without specs what would you guys do? Any suggestions?
    Thanks
    progmpg
    progmpg
    Reply 6 years ago
    ok, my math was off it appears I may need 36w 12vdc supply. Still I would like to know what you all think. I saw 1 you tube video where their supply was 12v 1amp, or 12W.
    diy_bloke
    diy_bloke
    7 years ago
    well done. I was just wondering: I understood that the ledstrip comes witha an IR remote. Why not just add an IR led to yr arduino and use that to control the strip(s)
    CarlS
    CarlS
    Reply 7 years ago
    Sure, that would be a great addition!
    TanL8
    TanL8
    7 years ago
    now have a new type digital led strip better than ws2812b, it's apa102 rgb led strip:www.sfleds.com
    you many have a try for decoration
    JmsDwh
    JmsDwh
    10 years ago on Introduction
    NIce job! I was thinking of doing something similar with some LED strips I found on Adafruit, but I realized I was starting too late to get something done by Christmas. I liked these ones because they are individually addressable, but they are also a lot more expensive.
    CarlS
    CarlS
    Yeah, those would be sweet! Clark Griswold would definitely go for them :-) Thanks!
    Donaisd
    Donaisd
    Reply 7 years ago
    Hey CarlS. Are you able to give me a hand creating a digital led strips for my home??
    KingtarLED
    KingtarLED
    8 years ago on Introduction
    Hello, we're manufacturer of digital rgb led strips.If someone needs digital leds,please contact us :www.kingtarled.com
    kuorus
    kuorus
    9 years ago on Step 2
    Amazing!!
    Did you have any problem with the current? I mean, several amps in a stripboard, with all the MOSFETS together... Is there a heatsink or special way needed? Thank you!
    CarlS
    CarlS
    Reply 9 years ago on Step 2
    Thanks! No heat problems - they are very high current and the TO-220 packaging has a big tab as a heat sink. The analog RGB LED strips are very cost effective, but I got a strand of digitally addressable ones, and I have to say they are pretty sweet :-) http://www.adafruit.com/products/738
