Introduction: Arduino Countdown Timer With Settings
In this tutorial we will learn how to make a Countdown Timer, where you can set time with one button and start the timer with another button. When timer reaches the zero the LED will start to flash. Instead of the LED you can connect anything else like a relay or any other module.
Watch the Video!
Step 1: What Will You Need
- Arduino UNO (or any other board)
- LED Display TM1637
- 2X button modules
- 1K ohm resistor
- LED
- Jumper wires
- Breadboard
- Visuino program: Download Visuino
Step 2: The Circuit
- Connect LED Display pin[CLK] to Arduino digital pin[10]
- Connect LED Display pin[DI0] to Arduino digital pin[9]
- Connect LED Display pin[GND] to Arduino pin[GND]
- Connect LED Display pin[VCC] to Arduino pin[5V]
- Connect button module1 and button module2 pin [Vcc] to Arduino pin [5V]
- Connect button module1 and button module2 pin [GND] to Arduino pin [GND]
- Connect button module1 pin [Out] to Arduino digital pin [4]
- Connect button module2 pin [Out] to Arduino digital pin [5]
- Connect Arduino digital pin [7] to 1Kohm resistor
- Connect other side of the resistor to LED positive pin [+]
- Connect LED negative pin [-] to Arduino pin [GND]
Step 3: Start Visuino, and Select the Arduino UNO Board Type
The Visuino: https://www.visuino.eu also needs to be installed. Download Free version or register for a Free Trial.
Start Visuino as shown in the first picture Click on the "Tools" button on the Arduino component (Picture 1) in Visuino When the dialog appears, select "Arduino UNO" as shown on Picture 2
Step 4: In Visuino Add Components
- Add "TM1637 7 Segment Display 4 Digits Module + 2 Vertical Points (CATALEX)" component
- Add "Up/Down Counter" component
- Add "Pulse generator" component
- Add "Divide Integer By Value" component
- Add "Multiply Integer By Value" component
- Add "Subtract Integer Value" component
- Add "Counter" component
- Add "Toggle(T) Flip-Flop" component
- Add 2X "Debounce button" components
- Add "Compare Integer Value" component
Step 5: In Visuino Set Components
- Select "Display1" and in the properties window set "Points" to True
- Double click on "Display1" component and in the "Digits" window
- drag "Integer Display 7 Segments" to the left side
- On the left side of the "Digits" window select "Integer Display 7 Segments1" and in the properties window set "Count Digits" to 2
- drag another "Integer Display 7 Segments" to the left side
- On the left side of the "Digits" window select "Integer Display 7 Segments2" and in the properties window set "Count Digits" to 2 and "Leading Zeroes" to True
- Close the "Digits" window
- Select "UpDownCounter1" and in the properties window setlect:"Initial Value" and click on the pin icon and select "Integer SinkPin"
Max > Roll Over" to False"
Min > Roll Over" to False
and Min Value to 0.
- Select "DivideByValue1" and in the properties window set Value to 60
- Select "MultiplyByValue1" and in the properties window set Value to 60
- Select "SubtractValue1" and in the properties window select Value and click on the Pin Icon and select "Integer SinkPin"
- Select "PulseGenerator1" and in the properties window
Select "Enabled" and click on the pin icon and select "Boolean SinkPin" and set "Enabled" to False
Step 6: In Visuino Connect Components
- Connect "PulseGenerator1" pin Out to "UpDownCounter1" pin Down
- Connect "UpDownCounter1" pin Out to "DivideByValue1" pin In and "SubtractValue1" pin In
- Connect "DivideByValue1" pin Out to "MultiplyByValue1" pin In and "Display1" > "Integer Display 7 Segments1" pin In
- Connect "MultiplyByValue1" pin Out to "SubtractValue1" pin Value
- Connect "SubtractValue1' pin Out to "Display1" > "Integer Display 7 Segments2" pin In
- Connect "Display1" pin Clock to Arduino digital pin 10
- Connect "Display1" pin Data to Arduino digital pin 9
- Connect Arduino digital Out pin [4] to "Button1" pin [In]
- Connect Arduino digital Out pin [5] to "Button2" pin [In]
- Connect "Button1" pin[Out] to "Counter1"pin [In] and to "TFlipFlop1" pin[Reset]
- Connect "Button2" pin[Out] to "TFlipFlop1" pin[Clock]
- Connect "TFlipFlop1" pin[Out] to "PulseGenerator1" pin[Enabled]
- Connect "Counter1" pin[Out] to "UpDownCounter1" first to pin[Reset] and then also to pin[Initial Value]
- Connect "UpDownCounter1" to "CompareValue1" pin[In]
- Connect "CompareValue1" pin[Out] to "Arduino" digital pin[7] , this pin will be used to turn the LED On
- Connect "CompareValue1" pin[Out] first to "Counter1" pin[Reset] and also to "UpDownCounter1" pin[Reset]
Step 7: Generate, Compile, and Upload the Arduino Code
In Visuino, at the bottom click on the "Build" Tab, make sure the correct port is selected, then click on the "Compile/Build and Upload" button.
Step 8: Play
If you power the Arduino module the LED Display will Show 00:00, if you start pressing .a Button (Connected to pin 4) the time on the display will increase by 1second each time, once you set your time, press the other button to start the countdown. On the Countdown zero a LED will turn On.
Congratulations! You have completed your project with Visuino. Also attached is the Visuino project, that I created for this Instructable, you can download it and open it in Visuino: https://www.visuino.eu
