Introduction: Arduino:The Cursor Show
Step 1: Step 1:Gather Your Parts
1) An arduino UNO or any other model will work just as fine.
2)An LCD shield (to make your project easier and more compatible) or any other LCD you know how to connect to the arduino.I'm using a 16 by 2 display if you're using a bigger or a smaller one make sure to change the line of code ill show you.
3)Two hands.
4)A USB A to B just like the ones commonly found on printers.You probably already have one that came with the arduino.
5)And a good mood
Step 2: Step 2:Connect the Lcd to the Arduino
https://www.instructables.com/id/Connect-A-16x2-LCD...
And here's how to connect a Nokia LCD to arduino:
[Play Video]
Step 3: Step 3:Fire Up the Code and Off You Go
The code can be tricky for a beginner but i was a beginner once as well and i'm going to do my best to explain it to you:
First of all include the library of the LCD display.The arduino IDE(integrated development environment) has it already installed for you just click sketch then include library and select the Liquid crystal one.After that you will need to declare the pins the LCD is hooked up to by using the command: LiquidCrystal(same as the name of the library)
(space) give it a name most commonly used name is LCD so ill stick to that
(open parenthesis) and now there are two cases if you're using the shield the active pins are:(8, 9 ,7 ,6 ,5 ,4)
for another display the most common pins are (12, 11, 5, 4, 3, 2)(notice how there's a space after each comma )
after you're done with stating the pins the line should look like this:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
or
LiquidCrystal lcd(8, 9, 7, 6, 5, 4);
Sorry for the inconvenience but you'll have to change it according to the lcd you're using
next in void setup(){}
write lcd.begin and the number of columns by the number of rows in this case (16,2)
void setup(){
lcd.begin(16,2);
other commands used in this sketch are:
lcd.print (prints a message on the lcd) everything you write should be contained in these bad boys " "
lcd.print("Hello world");
lcd.cursor which sets a cursor at the requested spot on the lcd display
lcd.setCursor(1,0);lcd.cursor();
lcd.blink blinks a cursor in the requested spot on the lcd
lcd.setCursor(0,2);
lcd.blink();lcd.noBlink
stops the cursor from blinking
lcd.noCursor
gets rid of the cursor no matter where he is
lcd.noDisplay
turns off the display
Step 4: Step 4:Have Fun
note:The code can do with some development and is not that good as i'm still new to programming any improvements and suggestions are appreciated
THANKS FOR READING MY INSTRUCTABLE
YOUR COMMENTS ARE WELCOME
