Introduction: Arduino DTMF Code Locker. a Hidden Lock for Your Secret Spaces.
Atmega328 device that listens for dial tones from mobile phone via a microphone.
So it can be placed behind the locked door without requiring extensive carpentry.
If code dialed matches the stored one lock will open for a few seconds.
Any arduino with atmega328 MC (Mine is arduino extra mini).
Microphone and LM358 or MAX4466(better) mic amp.
RGB led with four pins, common "-".
Some transistor to control lock or motor or whatever.
Step 1:
Connect pins as:
R led - D5
G led - D6
B led - D7
Audio input - A0
Reset button - D12
Lock pin - D8
Step 2:
Compile with arduino sources or burn already compiled.
- Connect all together and poweron.
- Dial the new password twice while the red led is on. 5 digits (0-9, *, #, A, B, C, D)
- Both the lock and master codes will be set to this password!
- If everything is set correctly, the white light (R+G+B) will appear. Reset.
- Now, enter the master code to change the lock code.
- Write down the master code somewhere, it is used to change the lock code.
- Dial lock code to get access to whatever.
Step 3:
Any mobile phone can be used, turn loud dialing tones on.
Also free app ToneDef from F-Droid repository allows to use whole 16 tones including extended ABCD chars.
