Arduino - Display Temperature and Humidity From DHT Using LCD Nextion
Intro: Arduino - Display Temperature and Humidity From DHT Using LCD Nextion
Hallo Everyone,
today i have some project
"Arduino - Display Temperature and Humidity From DHT Using LCD Nextion"
you can watch my video in my channel youtube
iam sorry because i use indonesian languange
next to list part
STEP 1: Part
part :
- lcd nextion 2.8"
- Sensor dht
- Arduino Uno Ultimate
- Buzzer 5v
- cables
STEP 2: Video Project
STEP 3: System
main menu:
- show humidity and temperature from DHT
- in top, you can see text temperature and humidity, this is indicator for show status like hot or cold, moist or dry, you can setting value for that in menu page
- in right position you can see text status and alarm,status for show are you connect with dht or no, if no, temperature,humidity,status,indicator will show 0 and error, if alarm on, buzzer will going on,
menu page:
- you can setting status for humidity and temperature in condition hot or cold and moist and dry
- you can setting alarm on or of
STEP 4: Trouble
if you watch my video you can find the trouble in menu page in alarm button, humidity page, temperature page, this is slow respond, i use "for" in arduino for make condition for get data from dht and show in lcd, and get data from button's, i cant make this program running with same void loop, if all program for get data dht and button in same loop without delay, menu page in temperatur, humidity or alarm cant be change, i have solution and use "for" In order to provide lcd chance to retrieve data from the touchscreen, I think this is not perfect even though it works,
Forgive me for this imperfect project,
STEP 5: Finally
you can downlod this program in this link
if you have any question, please comment
thanks
Bintang.
4 Comments
bugrapolat96 4 years ago
VladimirM70 6 years ago
nice :)
I also made short tutorial on hot to control one Nextion display from Docklight RS232 terminal.
https://www.youtube.com/watch?v=x7AHViVyMs8&feature=youtu.be
Very
often users forget to send 0xff byte value 3 times at the end of every
command. If you remember that you do not need Arduino Nextion library
and can use this display with any microcontroller.
BintangPz 6 years ago
thanks, maybe i will try your tutorial
