Introduction: Arduino Fun Fun Series: LED Controller Using Keyboard Inputs!
Heya everybody! How are you doing today? I hope everyone is fine and good always. Ok so today, i am going to demonstrate on how to turn on and off and control brightness of LED using keyboard input. This project is the offshoot of the original one Alternating Light Ups and Alternating Light Ups with Input . Without further delays, lets get to the objective and items needed for the project
Objective:
1.To Turn on and off LED using keyboard input
2. To increase and decrease brightness of LED using keyboard input
Items Needed:
1. Arduino Board( Arduino UNO is recommended, i am using the MEGA varient)
2. LED(any color you like)
Step 1: The Schematics
So far the schematics for this project is pretty simple. Basically, we just need to plug in the LED at pin 13 and Ground.The negative leg goes to the ground while the positive leg goes to pin 13.
Step 2: Coding the Project
As usual, i like to divide my code into three parts, namely, Declaration, Setting Up and Code Body/Execution.
Declaration(written before void_setup():
String ledcontrol; //i am going to declare string that is used to control the LED
int led = 13; // LED at pin 13
int brightness = 0; // a variable to store brightness value
Setting up:
void setup()
Serial.begin(9600); // declare serial port baud rate
pinMode(led, OUTPUT); // led as an output
delay(2000); // delay for 2 seconds
Serial.println("This experiment is to test input from keyboard to turn on and off led. Use command on to turn on and command off to turn off the led"); //a simple print out on what to do
Execution Code:
void loop() {
if(Serial.available()){ //check if serial monitor working
ledcontrol = Serial.readStringUntil('\n'); // this variable will read any input keyed in serial monitor
if(ledcontrol == "on") // if we key in on in the serial monitor
brightness = 255; // set the brightness to highest
Serial.println(ledcontrol); // print the brightness value
analogWrite(led, brightness); // write the value of brightness to the led (Means led will turn on and light up to the highest
else if(ledcontrol == "off") // if we key in off in the serial monitor
brightness = 0; // set the brightness to lowest
Serial.println(ledcontrol); // same as on loop
else if (ledcontrol == "up") // if we key in up in the serial monitor
brightness = brightness + 10; // add the current value of brightness with 10 analogWrite(led, brightness);// same as the on loop
Serial.print("led brightness is: ");
Serial.println(brightness);
else if (ledcontrol == "down")// if we key in down in the serial monitor
brightness = brightness - 100; // subtract the current value of brightness with 100 analogWrite(led, brightness);
if (brightness < 0)// and if the value is less than 0
brightness = 0; // maintain the value as 0
else {
Serial.println("invalid command"); // if you key in something else other than the commands above, the led will blink and say invalid command
digitalWrite(led, HIGH);
delay(1000);
digitalWrite(led, LOW);
delay(1000);
Step 3: Test It Out!
Now for the final part! Upload the code into your Arduino and open up the serial monitor. Key in the words "on", "off", "up", and "down". See what does the input does to the led and enjoy! I'll be back with more experiments to share to all of youuuuuuuu!
