Introduction: Arduino Jazz Improviser
This design does not play a "song." Instead, it uses a blues scale to create its own music while it plays - similar to a real jazz musician. Every time you turn it on it will play something different; but you can still control the tempo, pitch, and volume with the dials. Hear an example of it playing below:
Step 1: What Is Jazz?
If you want the official definition, you can look at these links, but I think the best way to describe it is just to show you what it sounds like.
Step 2: Build the Circuit
I built a stand for my speaker out of drinking straws and tape, but that is optional. Follow the diagram to build the rest of this design.
Step 3: Upload the Code
This code follows a pseudo-random algorithm to infinitely play the notes of the Bb blues scale in a jazzy syncopated rhythm.
Use this code in the Arduino IDE:
int note = 1;
int note2 = 1;
void setup() {
pinMode(3, OUTPUT);
void loop() {
int tonecontrol = map(analogRead(A0), 0, 1023, 1, 4);
int speedcontrol = map(analogRead(A1), 0, 1023, 1, 20);
int tonecontrol2 = map(analogRead(A2), 0, 1023, 1, 4);
int playnote;
int switchval = random(1, 5);
switch (switchval) {
case 1:
note = note;
break;
case 2:
note = note + 1;
break;
case 3:
note = note - 1;
break;
case 4:
note = note + 2;
break;
case 5:
note = note - 2;
break;
switch (note) {
case 1:
playnote = 262;
break;
case 2:
playnote = 294;
break;
case 3:
playnote = 311;
break;
case 4:
playnote = 349;
break;
case 5:
playnote = 392;
break;
case 6:
playnote = 440;
break;
case 7:
playnote = 466;
break;
case 8:
playnote = 523;
break;
default:
note = 1;
break;
playnote = playnote * tonecontrol;
int playnote2;
int switchval2 = random(1, 5);
switch (switchval2) {
case 1:
note2 = note2;
break;
case 2:
note2 = note2 + 1;
break;
case 3:
note2 = note2 - 1;
break;
case 4:
note2 = note2 + 2;
break;
case 5:
note2 = note2 - 2;
break;
switch (note2) {
case 1:
playnote2 = 262;
break;
case 2:
playnote2 = 294;
break;
case 3:
playnote2 = 311;
break;
case 4:
playnote2 = 349;
break;
case 5:
playnote2 = 392;
break;
case 6:
playnote2 = 440;
break;
case 7:
playnote2 = 466;
break;
case 8:
playnote2 = 523;
break;
default:
note2 = 1;
break;
playnote2 = playnote2 * tonecontrol2;
tone(3, playnote, 30 * speedcontrol);
delay(31 * speedcontrol);
if (random(1, 4) == 3) {
delay(21 * speedcontrol);
else {
tone(3, playnote2, 20 * speedcontrol);
}Step 4: How to Control It
From left to right, each dial does as follows:
- Volume
- 1st tone's pitch
- Tempo
- 2nd tone's pitch
Mess around with them until you get a sound you like.
