Introduction: Arduino - LDR With LED
This is simple arduino project; turn on LED when it's dark and turn off when is light.
Step 1: Hardware Required :
- Arduino Uno
- LED
- LDR (photoresistor)
- 220 and 10k ohm resistors
- Wires
- Breadboard
Step 2: LED Connection
- LED attach to board
- Resistor (220 ohm) one leg attach to LED long leg
- The green wire attach to resistor's empty leg
- The brown wire attach o LED short leg
Step 3: LDR Connection
- LDR attach to board
- Resistor (10k ohm) attach to LDR one leg
- The purple wire attach to LDR other (empty) leg
- The yellow wire attach to LDR and resistor same column
- The white wire attach to resistor empty leg
Step 4: Arduino Connections
- The green wire connect to digital 13 from resistor leg
- The brown wire connect to GND from LED short leg
- The purple wire connect to +5V from LDR
- The yellow wire connect to A0
- The white wire connect to GND
Step 5: Code
const int ledPin = 13;
const int ldrPin = A0;
void setup() {
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
pinMode(ldrPin, INPUT);
void loop() {
int ldrStatus = analogRead(ldrPin);
if (ldrStatus <=300) {
digitalWrite(ledPin, HIGH);
Serial.println("LDR is DARK, LED is ON");
else {
digitalWrite(ledPin, LOW);
Serial.println("---------------");
Step 6: If It Helps, Please Subscribe
First of all, I would like to thank you for reading this guide ! I hope it helps you.
If you want to support me, you can subscribe my channel and watch my videos.
