Introduction: Arduino LED Chaser ( With 8 Effects )
In this project, I rebuild the original one, change the effects from 5 to 8.
Original link: https://www.instructables.com/Arduino-LED-Chaser-With-5-Effects-/
Step 1: Step 1: Prepare the Material
1. Breadboard x1
2. Arduino uno x1 (with cable )
3. LED x9
4. Jumper cables
( The materials are same as the original one, the difference is in the code)
Step 2: Step 2: Connection
1. Take Jumper cables from GND to the positive electorate
2. Take Jumper cables and plug to digital pin 1 to 9of Arduino.
3. Connect the ground pin of Arduino with the negative side of all LED light.
Step 3: Step 3: Code
void setup()
{ pinMode(1,OUTPUT); pinMode(2,OUTPUT); pinMode(3,OUTPUT); pinMode(4,OUTPUT); pinMode(5,OUTPUT); pinMode(6,OUTPUT); pinMode(7,OUTPUT); pinMode(8,OUTPUT); pinMode(9,OUTPUT); pinMode(10,OUTPUT); }
void loop() { int i;
// 1st pattern repeat 1 times
for(i=1; i<=10; i++) { digitalWrite(i,HIGH); delay(50); digitalWrite(i,LOW); delay(50); }
for(i=10; i>=1; i--) { digitalWrite(i,HIGH); delay(50); digitalWrite(i,LOW); delay(50); } delay(1000);
//2nd pattern repeat 1 times
for(i=1; i<=10 ; i++) { digitalWrite(i,HIGH); delay(50); }
for(i=1; i<=10 ; i++) { digitalWrite(i,LOW); delay(50); }
for(i=10; i>=1 ; i--) { digitalWrite(i,HIGH); delay(50); }
for(i=10; i>=1 ; i--) { digitalWrite(i,LOW); delay(50); } delay(1000);
//3rd pattern repeat 2 times (改)
for(i=1; i<=10 ; i++) { digitalWrite(i,HIGH); delay(50); } for(i=11; i>=1 ; i--) { digitalWrite(i,LOW); delay(50); }
for(i=10; i>=1 ; i--) { digitalWrite(i,HIGH); delay(50); } for(i=1; i<=10 ; i++) { digitalWrite(i,LOW); delay(50); } delay(1000);
//4th pattern repeat 2 times (改)
for(i=1; i<=5 ; i++) { digitalWrite(i,HIGH); digitalWrite(11-i,HIGH); delay(100); } for(i=1; i<=5 ; i++) { digitalWrite(i,LOW); digitalWrite(11-i,LOW); delay(100); } delay(100); for(i=1; i<=5 ; i++) { digitalWrite(i,HIGH); digitalWrite(11-i,HIGH); delay(100); } for(i=5; i>=1 ; i--) { digitalWrite(i,LOW); digitalWrite(11-i,LOW); delay(100); } delay(1000);
//5th pattern rpeat 2 time (改
for(i=1 ; i<=3 ; i++) { digitalWrite(i,HIGH); digitalWrite(i+3,HIGH); digitalWrite(i+6,HIGH); delay(500/i); } delay(500);
for(i=1 ; i<=3 ; i++) { digitalWrite(i,LOW); digitalWrite(i+3,LOW); digitalWrite(i+6,LOW); delay(500/i); }
delay(1000);
Step 4: Step 4: Final Video
