Introduction: Arduino Laser-Tag Vest Module (Part.4)
About: J.D Electronic has bee designing a large range of DIY Arduino / Picaxe Electronic Kit-sets and Products for Hobbyists, Electricians and Schools Be sure to check out our New DIY Laser-tag game system kit.
Here is the Stage.4 on building up the vest module
Now you can build your own high -tech laser-tag system using Arduino, bringing the futuristic thrill of laser-tag Innovations kits - directly to you. This laser-tag system is a fully functional laser-tag set in kit-form, allowing you to build your own arena and gear.
The complete kit comes with all parts includes the following items (front, back, Phaser Gun parts and Shoulders 3D case, all Resistors, Transistors, I/R receiver diodes, I/R Tx diodes, Laser, Battery Charger, Cable and Body vest with cable and fixing plates attached for you. (plug & play)
Build your own DIY Laser-tag system “Great fun” Ideal for schools, clubs, and hobbyists
If you want to purchase a complete kit ( All parts supplied) or a Short-form kit (All PCBs components assemble and tested only) Also you can purchase any spare parts as well. Please Contact us.
Contact Information:
James: Email: ledxtreme27@gmail.com
David: Email: inspectholdings@outlook.com
Assemble Stages
  1. Front Pack build - Part.1
  2. Back Pack build - Part.2
  3. Shoulders Left/Right build - Part.3
  4. Vest Assembly Part.4
  5. Phaser Gun build - Part - 5
  6. Battery Charger build - Part.6
  7. Remote Electronic Score-Board build - Part.7
  8. "New" Sentry Target Control build - Part.8 (In the Development stage)
  9. "New" EMC Terminator Control Device build - Part.9 (In Development stage)
Laser-tag front pack kit, before starting this project. Please check all parts against the ----- list below.
FRONT LASER PACK PARTS ONLY
DESCRIPTION QTY
Front PCB Completely built (by you) ------------------ 1
Back PCB completely built (by you) ------------------- 1
Shoulders left/right built (by you) -------------------- 1
Case M3 Screws --------------------------------------- 6
Front 3D Print Case ------------------------------------ 1
Vest Design -------------------------------------------- 1
PCB Screws -------------------------------------------- 6
Step 1: - Vibrate Motor
Glue the vibrate motor to the PCB, solder pads (CON4) then solder the Red wire (+) to the top of the PCB. Next solder the Blue wire (-) underneath of PCB.
Step 2: - Phaser Gun Cable Lead
Solder the pre wired phaser cable to the front PCB solder pads (CON3) NOTE: Make sure that you connect each of the wires to the correct pads. The wiring colour code as follows BLACK = GND / WHITE = 7.4V / RED = +5V / ORANGE = LED1 / YELLOW = P/H / GREEN = VSK (see photo) Next attach the cable tie in kit to the phaser gun cable wired end. (see photo).
Step 3: - Charging Wires
First mount the pre wired charging socket to the front case use two M3 screws with nuts then solder the 3 coloured wire from charging socket on the right side of the front case (front facing towards you) to the PCB solder pads (CON4) NOTE: Make sure that you connect each of the wires to the correct pads. The wiring colour code as follows BLACK = GND / RED = +5V / GREEN = VSK (see photo)
Step 4: - OLED Lead
Connect the 5 pin wire lead plug to the OLED Display (see photos). NOTE: Make sure it connected the right way round.
Step 5: - Front Cable Leads
Insert the two 8 pin plug into the sockets (left and right side).
Step 6: - Cable Leads to Front PCB
Bend and fold the cable lead underneath the PCB. (left and right side)
Step 7: - Attaching the Front PCB
Place the front PCB down onto the front case plate with the word (FRONT) printed on the plate. make sure the cable leads are not twisted up and away from the mounting screw holes. Next screw down the PCB with the six M3 screws in the kit. ---- NOTE: Do not overtighten the screws.
Step 8: - Attach Front / Back Casing
Place the front casing down onto the front base plate then screw down the case with M3 screws in the kit.
Step 9: - Shoulder Cable Leads
Insert the two 8 pin plug into the sockets, Next bend and fold the cable lead underneath the PCB. (left and right side)
Step 10: - Shoulder PCBs to Vest
Place the PCB down onto the shoulder case plate with the word, Make sure the cable leads are not twisted up and are away from the mounting screw holes. Next screw down the PCB with the six M3 screws in the kit. ---- NOTE: Do not overtighten the screws. Repeat the same for the other side.
Step 11: -Attach Casing
Attach the left lid casing top down onto the shoulder plate making sure it is facing inwards. (side without a lens) near the neck of the vest. Once in place then screw down the case with M3 screws in the kit.
Step 12: - Back Cable Leads
Step 13: - Cable Leads to Back PCB
Step 14: - Attaching the Switch
Mount the on/ff LED switch to he back casing then tighten with the nut.
Step 15: - Attaching Back PCB
Place the back PCB down onto the front case plate with the word (BACK) printed on the plate. make sure the cable leads are not twisted up and away from the mounting screw holes. Next screw down the PCB with the six M3 screws in the kit. ---- NOTE: Do not overtighten the screws.
Step 16: -Attach Back Casing
Place the Back casing down onto the back base plate (mark BACK) then screw down the case with M3 screws in the kit.
Step 17: - Completed Vest Finished
The complete finished vest pack ready for testing.
