Introduction: Arduino Led Dice
This explaines how to create it in the breadboard, how to solder it and how to make some changes.
Step 1: What Is Arduino?
Arduino can be used to develop interactive objects, taking inputs from a variety of switches or sensors, and controlling a variety of lights, motors, and other physical outputs. Arduino projects can be stand-alone, or they can be communicate with software running on your computer (e.g. Flash, Processing, MaxMSP.) The boards can be assembled by hand or purchased preassembled; the open-source IDE can be downloaded for free.
The Arduino programming language is an implementation of Wiring, a similar physical computing platform, which is based on the Processing multimedia programming environment.
Why Arduino?
There are many other microcontrollers and microcontroller platforms available for physical computing. Parallax Basic Stamp, Netmedia's BX-24, Phidgets, MIT's Handyboard, and many others offer similar functionality. All of these tools take the messy details of microcontroller programming and wrap it up in an easy-to-use package. Arduino also simplifies the process of working with microcontrollers, but it offers some advantage for teachers, students, and interested amateurs over other systems:
- Inexpensive - Arduino boards are relatively inexpensive compared to other microcontroller platforms. The least expensive version of the Arduino module can be assembled by hand, and even the pre-assembled Arduino modules cost less than $50
- Cross-platform - The Arduino software runs on Windows, Macintosh OSX, and Linux operating systems. Most microcontroller systems are limited to Windows.
- Simple, clear programming environment - The Arduino programming environment is easy-to-use for beginners, yet flexible enough for advanced users to take advantage of as well. For teachers, it's conveniently based on the Processing programming environment, so students learning to program in that environment will be familiar with the look and feel of Arduino
- Open source and extensible software- The Arduino software and is published as open source tools, available for extension by experienced programmers. The language can be expanded through C++ libraries, and people wanting to understand the technical details can make the leap from Arduino to the AVR C programming language on which it's based. SImilarly, you can add AVR-C code directly into your Arduino programs if you want to.
- Open source and extensible hardware - The Arduino is based on Atmel's ATMEGA8 and ATMEGA168 microcontrollers. The plans for the modules are published under a Creative Commons license, so experienced circuit designers can make their own version of the module, extending it and improving it. Even relatively inexperienced users can build the breadboard version of the module in order to understand how it works and save money.
How do I use Arduino?
Step-by-step instructions for setting up the Arduino software and connecting it to an Arduino Duemilanove:
Step 2: Parts & Tools
Parts:
- Arduino
- 7x Leds of any kind (I use 5mm Red Leds)
- A 10k Resistor (brown black orange)
- 7x 220 or 330 Resistor (red red brown or orange orange brown)
- A little Push Button
- Breadboard
- Some wires for the breadboard
- The arduino programmer (you can download it from the official site of Arduino)
- Usb Cable A-B
- Soldering Iron (If you want solder the project)
- A ProtoBoard (f you want solder the project)
- Solder Spool (If you want solder the project)
- Third Hand (optional, but useful if you want solder the project)
Step 3: Schematic & Intro
To create all the faces of the dice, you must follow these rules:
For the number 2 of the dice: lights up the group 1
For the number 3 of the dice: lights up the groups 3 and 4
For the number 4 of the dice: lights up the groups 1 and 3
For the number 5 of the dice: lights up the groups 1, 3 and 4
For the number 6 of the dice: lights up the groups 1, 2 and 3
Step 4: Place the Components on the Breadboard
After that, connect all the cathodes of the Leds to ground with 220 or 330 ohm resistors (red red brown or orange orange brown)
Then, put the pushbutton on the breadboard and connect it to ground with 10k ohm resistance.
Step 5: Connect the Components With Arduino
First, attach the Arduino ground with the ground line of the breadboard
Then, connect the Leds to Arduino...this part can be a bit difficult, but there is an useful schematic.
Finally, connect the 5v of arduino with the button, and connect the button with the pin 6 of Arduino...be careful also in this part and follow the picture.
Hey...you're done!
Step 6: Program Code
This is the code without the comments to reduce the space (You can find the comments in the downloadable file):
int pinLeds1 = 10;
int pinLeds2 = 9;
int pinLeds3 = 7;
int pinLed4 = 8;
int buttonPin = 6;
int buttonState;
long ran;
int time = 2000;
void setup ()
pinMode (pinLeds1, OUTPUT);
pinMode (pinLeds2, OUTPUT);
pinMode (pinLeds3, OUTPUT);
pinMode (pinLed4, OUTPUT);
pinMode (buttonPin, INPUT);
randomSeed(analogRead(0));
void loop()
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH){
ran = random(1, 7);
if (ran == 1){
digitalWrite (pinLed4, HIGH);
delay (time);
if (ran == 2){
digitalWrite (pinLeds1, HIGH);
delay (time);
if (ran == 3){
digitalWrite (pinLeds3, HIGH);
delay (time);
if (ran == 4){
delay (time);
if (ran == 5){
delay (time);
if (ran == 6){
digitalWrite (pinLeds2, HIGH);
delay (time);
digitalWrite (pinLeds1, LOW);
digitalWrite (pinLeds2, LOW);
digitalWrite (pinLeds3, LOW);
digitalWrite (pinLed4, LOW);
Step 7: Test It!
Now the Arduino led dice is finished and you can try it...you just have to power Arduino and press the button to see the number!
This project is very useful for those who wants to begin to become familiar with Arduino, the code is easy, clean and funny.
Now, if you want to improve the project, you can try to solder it or make some changes, as explained in the next steps of instructable.
Step 8: Solder the Arduino Led Dice
If you want, you can also solder the project, to make it more compact and better.
Solder is not easy, and if you are a beginner, I recommend to follow some guides on the web to learn it.
In the images, there's my old solder version of my Arduino led dice, and unfortunately, in this version each led is connected to an Arduino pin: during soldering, it's advisable to connect the LEDs in pairs as in the breadboard version, for convenience.
Step 9: Project Variations
If you want to do this, simply connect the tilt switch to the 5V Arduino and the other side to pin 6 of Arduino, as in figure.
in this:
if (buttonState == LOW) {
Finalist in the
Arduino Contest
27 People Made This Project!
- milandeepak made it!
- SeanCarr451 made it!
- Winteractive made it!
- HowOVE made it!
- Hong Jyun Wang made it!
- janewu331 made it!
- Chieh Liu made it!
See 18 More
60 Comments
9 months ago
thanks, that was fun! it is convenient to replace ran = random(1, 7); by ran = 1; // etc. to test the possible outcomes
3 years ago
thanks! we had to modify the code to get ours to cycle through all 6 proper die configurations. -aiden z
void loop()
//Read the status of the button
//Randomize from 1 to 6
ran = random(7);
//Number 1!
if (ran == 1){
delay (time);
//Number 2!!
if (ran == 2){
delay (time);
//Number 3!!!
if (ran == 3){
delay (time);
//Number 4!!!!
if (ran == 4){
delay (time);
//Number 5!!!!!
if (ran == 5){
delay (time);
//Number 6!!!!!!
if (ran == 6){
delay (time);
//If the button is not pressed, sets off the leds
//....Finish!
Question 3 years ago on Step 6
Hi. What would be the modifications on the code if I wanted to have 3 dice all having a random output.
Question 4 years ago on Step 4
does it need to be 10k cuz i dont have any
Answer 3 years ago
It can be pretty much any large value resistor. It is acting as a pull down resistor to keep the voltage at a logic 0. Resistors in series are additive so you can always add a few together to get a desired amount.
5 years ago
can someone explain to me .. Why analogread(0)? May I use analogRead(1) ? Or digitalRead ...
Reply 4 years ago
it can be any unused (analog) pin to read random static noise as seed generator for random number...
5 years ago
Some mistakes in electrical schematic !!!
5 years ago
It's quite fun playing with this electronic dice.
5 years ago
I will start doing now.
6 years ago
it was not working i made it two times can you help me
6 years ago
Nice Instructable. Thanks for sharing.
6 years ago
Thank you sooo much for this good informations and this amazing website
7 years ago
Thanks for the Great Tutorial!
I made a Arduino Dice Game 10.000 very cool
https://www.youtube.com/watch?v=FM2D7WqH6cY
7 years ago
/*Here is the Code for Dice with 7-SEGMENT Display as well as Led's will glow up acording to Dice Random Number
Simulation Software is Proteus*/
int led[]={38,39,40,41,42,43};
int a=22,b=23,c=24,d=25,er=26,f=27,g=28,buttonpin=32 ;
void setup() {
// put your setup code here, to run once:
//pinMode(led1,OUTPUT);
pinMode(a,OUTPUT);
pinMode(b,OUTPUT);
pinMode(c,OUTPUT);
pinMode(d,OUTPUT);
pinMode(er,OUTPUT);
pinMode(f,OUTPUT);
pinMode(g,OUTPUT);
pinMode(buttonpin,INPUT);
for(int i=0;i<=5;i++)
pinMode(led[i],OUTPUT);
void loop() {
int x,y,j;
// put your main code here, to run repeatedly:
Back:
y=digitalRead(buttonpin);
if(y==0)
goto Back;
x=random(7);
if(y==1 && x==1)
goto Dice_1;
else if(y==1 && x==2)
goto Dice_2;
else if(y==1 && x==3)
goto Dice_3;
else if(y==1 && x==4)
goto Dice_4;
else if(y==1 && x==5)
goto Dice_5;
else if(y==1 && x==6)
goto Dice_6;
else
goto Back;
Dice_1:
digitalWrite(b,HIGH);
digitalWrite(c,HIGH);
digitalWrite(a,LOW);
digitalWrite(d,LOW);
digitalWrite(er,LOW);
digitalWrite(f,LOW);
digitalWrite(g,LOW);
digitalWrite(led[0],HIGH);
delay(1000);
digitalWrite(led[0],LOW);
delay(500);
goto Back;
//goto Back;
Dice_2:
digitalWrite(c,LOW);
digitalWrite(a,HIGH);
digitalWrite(d,HIGH);
digitalWrite(er,HIGH);
digitalWrite(g,HIGH);
digitalWrite(led[1],HIGH);
delay(1000);
digitalWrite(led[1],LOW);
delay(500);
goto Back;
Dice_3:
for(j=0;j<=2;j++)
pinMode(led[j],HIGH);
delay(1000);
for(j=0;j<=2;j++)
pinMode(led[j],LOW);
delay(500);
goto Back;}
Dice_4:
digitalWrite(f,HIGH);
for(j=0;j<=3;j++)
digitalWrite(led[j],HIGH);
delay(1000);
for(j=0;j<=3;j++)
digitalWrite(led[j],LOW);
delay(500);
goto Back;
Dice_5:
digitalWrite(b,LOW);
for(j=0;j<=4;j++)
delay(1000);
for(j=0;j<=4;j++)
delay(500);
goto Back;
Dice_6:
for(j=0;j<=5;j++)
delay(1000);
for(j=0;j<=5;j++)
delay(500);
goto Back;
7 years ago on Introduction
n
finish this project with some boy scouts. basic starter kit, couple extra LEDs, 2 hours working with the boys. I liked some of the type o it allowed for troubleshooting. great starter project
7 years ago on Step 6
It works!! But i think there is an error in the code, at pin set:
int pinLeds3 = 7;
int pinLed4 = 8;
Should be:
int pinLeds3 = 8;
int pinLed4 = 7;
I'm going to try with a tilt switch as you suggested.
Thanks!!
