Arduino Logic Probe
Intro: Arduino Logic Probe
This project is an instrument of measuring so that you can measure logic levels of voltage. That is, with an Arduino Uno, and a 3-digit common cathode display, you will probe logic levels as zeros and ones, even pulses. For obtaining the code, you can go to: http://pastebin.com/cCBQLDyU
What you will need:
Soldering iron and solder
Wire strippers and cutter
Needle nose pliers
Multimeter
22 AWG wire, 1 meter
STEP 1: List of Materials
1 Arduino Uno Proto Shield (PCB only)
1 ABS Plastic Enclosure for Arduino Boards - Fits UNO or MEGA
1 Displays Segmented Panel 3DIGIT 24LED Orange CC 12-Pin DIP
1 Arduino Uno R3 DIP Edition (Revision 3)
7 Resistor Carbon Film 220 Ohm 1/4 Watt 5%
1 Resistor Carbon Film 10k Ohm 1/4 Watt 5%
1 Connector Unshrouded Header 40 Position 2.54mm Straight Thru-Hole
1 Test Lead Red
1 Cable USB2.0 A/B 3 Feet Black USB-A Male To USB-B Male
1 9V Battery Snap with 2.1mm Barrel Plug
STEP 2: Schematic Diagram
This is the project's general diagram where you see each connection for carrying out your project successfully. That is, it's an easy way of following the project and with it to avoid errors.
STEP 3: Identifying the 3 Digit CC Display
Observing carefully this Display, you will connect correctly the device because the corresponding pins are exactly the same, the picture and the component physically.
STEP 4: Installing the 3-Digit CC Display
Installing the led display, you can realize how it is fitted perfectly in the PCB. This photo is to your help.
STEP 5: 3 Digit Back Side CC Display
This picture describes how to make each connection to your display. In this side of the PCB, follow the instructions to avoid errors. Note the clear directions to connect correctly the 3-digit display.
STEP 6: Connecting the 3-Digit CC Display to Its Resistors
With the step #5 and the help of the project's diagram, install and solder the resistors to your display and Arduino pins respectively.
STEP 7: Completing the Connections to Your Display
This picture shows how to complete the rest of connections to your display. To complete this step, make the connections to the common display pins, d1, d2, and d3.
STEP 8: Installing the Resistor 10K
This picture shows how to connect the resistor of 10K to Arduino pin 10 and GND respectively. Also, the connection of GND to GND close to 5V pin on your PCB.
STEP 9: Preparing the Pins
Taking the Connector Unshrouded Header 40 Position 2.54mm Straight Thru-Hole, cut the pins that you will need to install in the project.
STEP 10: Inserting the Pins Into the Arduino
Install the pins previously prepared in the step #9.
STEP 11: Soldering the Pins
This picture shows the pins are already installed and soldered.
STEP 12: Front View After Installing the Pins
With this front view of your project, you can realize if everything is OK.
STEP 13: Preparing the Test Lead
This picture shows how to prepare the test lead of your project.
STEP 14: Installing the Test Lead
This picture shows how to install the test lead.
STEP 15: Front View After Installing the Test Lead
In this front view of your project, you can verify if everything is OK with help of the schematic.
STEP 16: Mounting the Project on the Arduino
With this front view of your project, you can already think on an enclosure.
STEP 17: Mount Your Project on the Arduino Enclosure
Mounting the project on the Arduino enclosure, you can already think about the code.
STEP 18: Uploading the Code
Upload the code so that you can use it to measure logic levels of voltage. Also note before measuring something, you will only see zeros because nothing is measured; and therefore, zero voltage is detected. For uploading the code, you can go to: http://pastebin.com/cCBQLDyU
STEP 19: Checking a Low Level of Voltage ("0")
Once uploaded the code, you can already measure logic zeros.
STEP 20: Checking a High Level of Voltage ("1")
Once uploaded the code, you can already measure logic ones.
32 Comments
braulio777 7 years ago
You can do your own project by modifying the code at:
If you want to upload the code for this project, you need to visit the next site:
LEATHERWORKING classes are now free in this site.
PHOTOGRAPHY classes are now free in this site.
BREAD classes are now free in this site.
CANNING PRESERVING classes are now free in this site.
WOODWORKING classes are now free in this site.
GLUE classes are now free in this site.
CONCRETE classes are now free in this site.
MEAT classes are now free in this site.
WEARABLE ELECTRONICS classes are now free in this site.
RASPBERRY PI classes are now free in this site.
LASER CUTTING classes are now free in this site.
LAMPS classes are now free in this site.
CNC classes are now free in this site.
3D PRINTING classes are now free in this site.
Robots classes are now free in this site.
Electronics classes are now free in this site.
Arduino classes are now free in this site.
LEDS & LIGHTING classes are now free in this site.
