Introduction: Arduino Mini Arcade Basketball Hoop - Final Project
What's up!
This guide will give you an overview on how I made my own mini arcade basketball hoop using the Arduino Nano RP2040 Connect, and how you can make your own as well! This hoop is a standard over-the-door mini hoop, but with a fun upgrade. When first turned on, the backboard LEDs flash a red light animation, the speaker plays an arcade basketball tune, blows the whistle, and you're off! When the ball passes through the basket, it is sensed by the APDS-9960 sensor and plays a randomized sound like "What a shot!" and "2 points!" while flashing a red, yellow and gold light animation.
I'm a huge fan of shooting some casual hoops in my dorm room, so I figured: why not get the crowd involved and spice up the game a little?!
- Arduino Nano RP2040 Connect
- Arduino pin board
- Arduino pin board wires
- Stemma QT Adafruit APDS-9960 sensor
- Over-the-door mini basketball hoop
- LED strips/lights
- Electrical tape
- Velcro Command strips
- Alligator clips
- Auxiliary port mini speaker
- Mirco-USB power bank
- Mu Editor Application
- CircuitPython
- Speedy 360 flexx - Trotec Laser
Step 1: Assemble Basketball Hoop and Design Project
For this project, I ended up buying a new over-the-door mini basketball hoop (I used this one from Dick's Sporting Goods). Out of the box, there was a little assembly required, but nothing major. After assembling the hoop and taking a few practice shots, it was time to start thinking about the design.
I originally wanted to tuck my Arduino and speaker behind the backboard, but because the backboard hangs flush against the door, this was not possible. So, I drew up a rendition that could house everything I needed (Arduino + board, APDS-9960 sensor, speaker, LED strip) on the front side of the backboard, without interfering too much with the play area.
Step 2: Arduino Coding!
After creating solid plan, it's time to code!
For my sounds, I edited mp3 files on the Audacity application to create 5 different .wav files. The first file sounds like the start-up tune of an arcade basketball hoop. The other 4 are reaction sounds to baskets being made-- "What a shot!", "2 points!", "3 points!", and "[crowd cheering]".
Once your sound files are set, you can begin coding! I have my code (and sounds) linked to this step!
I created 2 functions--one that commences at the start of the game and one that activates whenever a basket is made. The sensor can detect anywhere from 1(farthest, only a couple inches away) to 255 (closest) proximity pulses, so I set a threshold such that if an object was closer than 1 proximity pulse away from the sensor (i.e. a ball passing through the basket), the reaction function would activate.
Tip: be sure that your speaker, LEDs, and APDS-9960 sensor are connected to the correct pins on your breadboard. I've attached an Arduino diagram and there is additional information in the linked videos!
I have additionally linked a couple of Prof. G's YouTube video tutorials, which were a HUGE help to me while configuring the audio files and APDS-9960 sensor. Check 'em out! He has some awesome videos that showcase additional Arduino capabilities and so much more!
Step 3: Physical Assembly
After finished coding, start putting all the pieces together! I needed my Arduino and all of its connections to be safe, so I designed a small box that would house the microcontroller and keep all of its attached pieces safe when shooting hoops. My speaker is outside the box, but I would recommend creating a box large enough to keep everything safe! To create the box, I made a design and communicated with our MakerSpace TA, Kevin, to create a vector file that could be printed on the Speedy 360 flexx Trotec Laser.
After glueing my laser-cut box together, I used velcro Command strips to attach everything to the backboard. You can use any sort of adhesion method, but I used the Command strips in this case for a clean removal of parts after assembly. My APDS-9960 sensor is located just below the rim so that it remains unharmed but is still close enough to sense objects going through the basket. I additionally wrapped by LED light connections in electrical tape to ensure a secure link.
And just like that, congratulations! You now have your own Arduino mini arcade mini basketball hoop. Have fun shooting hoops, with the crowd and lights by your side!
