Arduino Mood Lamp
3,323
9
Introduction: Arduino Mood Lamp
Hello Instructables Users!!! This is a simple, fun, and useful project for arduino beginners. You will be building the lamp and then uploading the code to make the lamp light up to a color of your liking. The color is smooth and lights up the area of your room you put it in.
Step 1: Step 1: Needed Parts
These are the parts needed to build the lamp:
1.) Jumper wires
2.) 120k Ohm resistor
3.) The LED color of your choice
4.) LDR (photo light resistor)
5.) Arduino Uno
6.) Breadboard
Step 2: Step 2: Building the Lamp
The following photo above is a schematic to build your mood lamp
Step 3: Step 3: Coding the Arduino
Copy and Paste the following code to use for your lamp:
void setup(){
pinMode(redLed,OUTPUT); pinMode(greenLed,OUTPUT); pinMode(blueLed,OUTPUT); digitalWrite(redLed,HIGH); digitalWrite(greenLed,LOW); digitalWrite(blueLed,LOW); }
void loop(){ for (int y=0; y<=3; y++) { if (y=1){ for (int x=0;x<=255;x++){ RGB[0]=255-x; RGB[1]=0; RGB[2]=0+x; analogWrite(redLed,RGB[0]); analogWrite(greenLed,RGB[1]); analogWrite(blueLed,RGB[2]); delay(delaymood); } } if (y=2){ for (int x=0;x<=255;x++){ RGB[0]=0; RGB[1]=0+x; RGB[2]=255-x; analogWrite(redLed,RGB[0]); analogWrite(greenLed,RGB[1]); analogWrite(blueLed,RGB[2]); delay(delaymood); } } if (y=3){ for (int x=0;x<=255;x++){ RGB[0]=0+x; RGB[1]=255-x; RGB[2]=0; analogWrite(redLed,RGB[0]); analogWrite(greenLed,RGB[1]); analogWrite(blueLed,RGB[2]); delay(delaymood); } } } }
Step 4: Step 4: Final Result
The final outcome of the lamp is a smooth color added to your room for light!
First Time Author Contest 2016
Robotics Contest 2016
Be the First to Share
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    • Hand Tools Only Challenge
    3 Discussions
    __dan__
    __dan__
    3 years ago
    The LDR related code is missing in the Arduino sketch!
    Seems like you just copied parts of the code from the original "Arduino Mood Lamp" instructable by ricardouvina! (https://www.instructables.com/id/Mood-Lamp-with-Arduino/)
    You have also copied and used the schematics and photos/images from the original author and made screenshots of his video!
    Can you please share any code, schematics, photos and videos of your own working mood lamp?
    Please be fair and honest and give credits to the original author (ricardouvina) and include a link to the original instructable if you knock off any source code, schematics, images and videos!
    The original author (ricardouvina) spend a lot of time and effort on his project. He did a great job and deserves better!
    You_know_me
    You_know_me
    3 years ago
    Can you please describe a bit more about how you made that tall lamp shade of yours ? It looks rather interesting!
    seamster
    seamster
    4 years ago
    Looks good! :)
