Arduino Mouse Wiggler
Intro: Arduino Mouse Wiggler
It is kind of annoying every time when the computer goes into sleep, especially when you are in the middle of a PowerPoint presentation, or working from home but supposed to appear available online all the time. This simple device will wiggle (jiggle) your mouse for you every 30 seconds or so and keep your computer always awake. This device simply simulates the physical mouse movement, there's no App or driver to be installed, so it is 'stealth' and won't violate the company IT policy or expose yourself to dangerous software.
STEP 1: Make the Device
The entire mouse wiggler is 3D printed. The files are attached. Print the parts with your favorite color.
STEP 2: Hardware and Assembly
The mouse wiggler uses parts that are available from many retailers. Following hardware are needed:
- Arduino Nano (or clone,don't solder the pins to the Nano)
- SG90 Servo and hardware pack
- Mini USB cable
- Some wires
Following are the steps to wire the servo to the Arduino Nano and installation of the servo and wheel.
The servo has a connector with 3 female pins. The orange one is the PMW pin that needs to be connected to the D9 pin on the Arduino Nano. The center Red wire is Vcc that goes to the +5V on the Nano and the Brown is ground that is connected to the GND on the nano. I used 3 male pins and soldered it to the wires from the Nano to make the wiring easier.
Use one of the servo horn and the screws to secure the SG90 servo to the mouse wiggler body, and install the wheel on the servo output. Make sure the wheel is level and does not interfere with the mouse. Optionally you can print the pattern and place it on top of the wheel to improve aesthetics and make the mouse move more consistent. I used white address labels for this.
STEP 3: Code
The Arduino sketch is attached. Make sure you have the Servo.h and SimpleTimer.h libraries installed before uploading the sketch to your nano. You may change the angle in which the servo will travel, and the time interval that the servo will move. The default setting is the servo will move the wheel 30 degrees to the left then 30 degrees to the right every 30 seconds. This will make your mouse move for about 10 mm which is enough for keeping the computer from sleep, yet not too much to lost track of the mouse cursor. You may adjust these values as you desire.
STEP 4: Let the Mouse Move
Place your mouse on top of the Mouse Wiggler and make sure the optical sensor on top of the wheel. Power the device up use a USB power adapter and you're good to go.
30 Comments
Astronomy Domine 3 years ago
I then went overboard and put in a load of (unnecessary) serial debug info which can be enabled by uncommenting 1 line :)
New code:
/**This is a modified version of the code found at:
https://www.instructables.com/Arduino-Mouse-Wiggl...
#include <Servo.h>
#include <SimpleTimer.h>
int servoPin = 9; //Servo attached to in 9
int mousePos = 20; // set the limit of mouse move (20 was plenty for me)
//Comment out the following 2 lines if you only need a repeating 30 second timer
#define MinimumTime 45 //Minimum time (in seconds) between mouse movements
#define MaximumTime 210 //Maximum time (in seconds) between mouse movements
Servo servo;
int angle = 0; // servo position in degrees
SimpleTimer timer(30000L); //This is how to decalre a 30 second timer with the version of SimpleTimer used
//Uncomment this if you want debug messages sent to the Serial Monitor
//#define DebugInfo
void setup()
#ifdef DebugInfo
Serial.begin(115200);
Serial.println("Serial output enabled.");
#endif
servo.attach(servoPin); //Attach the servo
servo.write(0); // Set Servo to 0 degrees
delay(15);
#ifdef DebugInfo
Serial.println("Servo set to 0 degrees.");
#endif
servo.detach(); //Detaching when not in use seems to prevent servo chatter/buzzing
randomSeed(analogRead(0)); //Get as close ro a random number as easily possible
void loop()
if (timer.isReady()) //Check if Simple Timer has reached it's trigger time
//Mouse Move
#ifdef DebugInfo
if (servo.attached())
Serial.println("Servo attached.");
else
Serial.println("Servo failed to attach.");
#endif
// scan from 0 to mousePos degrees
for(angle = 0; angle <= mousePos; angle++)
servo.write(angle);
delay(15);
// now scan back from mousePos to 0 degrees
for(angle = mousePos; angle >= 0; angle--)
servo.write(angle);
delay(15);
#ifdef DebugInfo
Serial.println("Servo move complete.");
#endif
servo.detach();
#ifdef DebugInfo
if (!servo.attached())
Serial.println("Servo detached.");
else
Serial.println("Servo failed to detach.");
#endif
#ifdef MinimumTime //only use random time if Min and Max are defined
#ifdef MaximumTime
#ifdef DebugInfo
long RandomTime = random(MinimumTime, MaximumTime);
timer.setInterval((RandomTime*1000));
Serial.print("Next Activation: "); Serial.print(RandomTime);Serial.println(" seconds.");
#else
timer.setInterval((random(MinimumTime, MaximumTime)*1000));
#endif
#endif
#else
#ifdef DebugInfo
Serial.println("30 second timer used.");
#endif
#endif
timer.reset(); //Restart the timer
EdwardM73 3 years ago
You'll probably find it on GitHub too.
Ed
samblaha 3 years ago
codingwolf 3 years ago
You just need to get the SimpleTimer.ccp file and the SimpleTimer.h file. Then replace one line in the main code that is posted in the article.
In the main code, change the include line to:
#include "SimpleTimer.h"
See images below:
SauliusP5 4 years ago
I've posted code that works in another comment.
ArtSuzhou 4 years ago
https://www.instructables.com/Arduino-Mouse-Wiggler/
#include <Servo.h>
int servoPin = 9;
int mousePos = 20; // set the limit of mouse move (20 degrees was plenty for me)
Servo servo;
void setup()
void mouseMove()
servo.write(angle);
delay(15);
servo.write(angle);
delay(15);
void loop()
//Thetimer.run() line is replaced by this code which triggers the mouse when the timer reaches 30 seconds
if (timer.isReady()) {
mouseMove();
timer.reset(); //Reset the timer
PacoT6 6 years ago
could you put out the code in the article because i cant open the file.
ArtSuzhou 6 years ago
I just tried the sketch can be downloaded without issue. It can be opened by Arduino IDE, or a text editor.
PacoT6 6 years ago
PacoT6 6 years ago
Thanor 3 years ago
Here is the code:
/**The MIT License (MIT)
Copyright (c) 2017 by Bin Sun
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
#include <Servo.h>
int servoPin = 9;
int mousePos = 30; // set the limit of mouse move
Servo servo;
SimpleTimer timer;
void setup()
timer.setInterval(30000L, mouseMove); //wiggle every 30 seconds
void mouseMove()
for(angle = 0; angle < mousePos; angle++)
servo.write(angle);
delay(15);
for(angle = mousePos; angle > 0; angle--)
servo.write(angle);
delay(15);
void loop()
timer.run(); //Initiate SimpleTimer
falias 6 years ago
just get an Atmega32u4 and send mouse commands. no empty mouse batteries, no loud servo, 1-2 lines of code in the loop
