Arduino Nano: Log GPS Information to MicorSD Card With Visuino
Intro: Arduino Nano: Log GPS Information to MicorSD Card With Visuino
MicroSD Cards are cheap and easy data storage medium, and they are very convenient for storing Arduino sensor data. There are also a number of cheap readily available MicroSD Card Modules for Arduino, and I already made Instructable on how to log Ultrasonic Ranger distance to MicroSD Card. I also made Instructable on how to display Location Information from GPS Module to LCD. Almost immediately somebody asked for for Instructable on logging GPS Information to MicroSD.
Logging data to the MicroSD is easy, but having file system management in Arduino takes memory, and can easily overwhelm small controllers like Arduino Uno or Nano. Indeed after the MicroSD support is added, Nano and Uno will have almost no memory available for anything else. We can use a controller with more memory such as the Mega or Teensy, however if we just record the serial data from the GPS Module to the MicroSD Card, we will have enough memory on the Arduino Nano, and we can process the data from the MicroSD later on another computer.
STEP 1: Components
- One Arduino compatible board (I use Arduino Nano, because I have one, but any other will be just fine)
- One GPS module
- One MicroSD Card Module
- One MicroSD Card
- One small Breadboard (Any breadboard can be used, or any other way to connect 3 wires together)
- 7 Female-Female jumper wires
- 3 Female-Male (Red) jumper wires
STEP 2: Start Visuino, and Select the Arduino Board Type
Since the Arduino Nano has only one Serial port, and it is needed to program the Arduino, you will need to program the Arduino Nano before the GPS is connected.
To start programming the Arduino, you will need to have the Arduino IDE installed from here: http://www.arduino.cc/ .
Please be aware that there are some critical bugs in Arduino IDE 1.6.6.
Make sure that you install 1.6.7 or higher, otherwise this Instructable will not work!
The Visuino: https://www.visuino.com also needs to be installed.
STEP 3: In Visuino: Add and Connect Micro SD Card Module Component
First we need to add and connect MicroSD Component in Visuino to control the MicroSD Module:
- Type "sd" in the Filter box of the Component Toolbox then select the "Micro SD Card Module" component (Picture 1), and drop it in the design area
- Connect the "Out" pin of the SDCard1 component to the to the "In" pin of the "SPI" channel of the Arduino component (Picture 2)
- Connect the "ChipSelect" output pin of the SDCard1 component to the "Digital" input pin of the "Digital[ 10 ]" channel of the Arduino component (Picture 3)
STEP 4: In Visuino: Add and Configure File Element to the MicroSD Card Component
To record the data we need to add File element to the MicroSD component and specify its file name:
- Click on the "Tools" button of the SDCard1 component (Picture 1)
- In the "Elements" editor select the “File” element in the right window, and then click on the "+" button on the left (Picture 2) to add File element
- In the Object Inspector set the value of the "Path Name" property of the File1 Element to "GPSLog.txt" (Picture 3)
STEP 5: In Visuino: Connect the Serial Port to the File Element
Connect the "Out" pin of the "Serial[ 0 ]" channel of the Arduino component (Picture 1) to the "In" input pin of the "Elements.File1" of the SDCard1 component (Picture 2)
STEP 6: Generate, Compile, and Upload the Arduino Code
- In Visuino, Press F9 or click on the button shown on Picture 1 to generate the Arduino code, and open the Arduino IDE
- In the Arduino IDE, click on the Upload button, to compile and upload the code (Picture 2)
STEP 7: Connect the MicroSD Module to Arduino
- Connect Female-FemaleCS(Gray Wire), SCK(Orange wire), MOSI(Blue wire), MISO(Purple wire), and Ground(Black wire) to the MicroSD Module
- Connect the Female end of a Female-MalePower(Red wire) to the VCC/Power pin of the MicroSD Module (Picture 1) , and leave the Male end unconnected
- Connect another Female-Male Power wire(Red wire) to the 5V Power pin of the Arduino board(Picture 2), and leave the Male end unconnected
- Connect the other end of the Ground wire(Black wire) to Ground pin of the Arduino board(Picture 2)
- Connect the other end of the SCK(Orange wire) to Digital pin 13 of the Arduino board(Picture 3)
- Connect the other end of the MISO(Purple wire) to Digital pin 12 of the Arduino board(Picture 4)
- Connect the other end of the MOSI(Blue wire) to Digital pin 11 of the Arduino board(Picture 4)
- Connect the other end of the CS(Gray wire) to Digital pin 10 of the Arduino board(Picture 4)
- Picture 5 shows in Red where are the Ground, 5V Power, Digital 10, Digital 11, Digital 12, and Digital 13 pins of the Arduino Nano
STEP 8: Connect the GPS Module to the Arduino
- Connect the Female end Female-MalePower(Red wire) to the GPS Module and leave the Male end unconnected
- Connect Female-Female Ground(Black wire), and TX(Yellow wire) to the GPS Module
- Connect the other end of the Ground wire(Black wire) to Ground pin of the Arduino board (Picture 2)
- Connect the other end of the TX (Yellow wire) to RX pin of the Arduino board (Picture 2)
- Picture 3 shows in Red where are the Ground, and RX pins of the Arduino Nano (In Blue are shown the connections made in the previous step)
STEP 9: Connect the Power Wires Together, and Plug the MicroSD Card in the Module
- Connect the Male ends of the 3 Power wires(Red wires) - from the MicroSD Module, the GPS Module, and the Arduino together as example with the help of a Breadboard (Picture 2) - In my case I used a small Breadboard
- Insert the MicroSD Card into the MicroSD Card Module (Picture 2)
STEP 10: And Play...
Congratulations! You have completed the project.
Picture 1 and the Video show the connected and powered up project. The LED on Digital Pin 13 of the Arduino will start flashing from time to time when new data from the GPS is recorded to the MicroSD Card.
On Picture 2 you can see example of the data recorded on the MicroSD Card.
On Picture 3 you can see the complete Visuino diagram.
Also attached is the Visuino project, that I created for this Instructable. You can download and open it in Visuino: https://www.visuino.com
9 Comments
elimsprint 6 years ago
Hi BoianM,
I have tried and tried but I cannot get this to work. Arduino Nano, generic GPS and SD card. I have Visuino and Arduino IDE installed. Windows10 64bit. When I try to compile it gives me the same error each time.
What am I doing wrong?
BoianM 6 years ago
Most likely you have the wrong path for the Sketchbook location in teh Arduino IDE.
Should be like this:
C:\Users\{USER NAME}\Documents\Arduino
You can also contact me directly to help you set it up.
I got it to load, I am going to wire it up now and see what happens:)
ОлексійГ 6 years ago
Hi BoianM,
Thanks for the instruction!
One question though..
I have did everything exactly as in the instruction, and I eventually got everything working together.
The GPSLog.txt file was created on the SD but the data in the file seems corrupt. Please see the example from beginning of the file below.
Any ideas what could be causing this? Plus there are no $GPRMC sentences in the output..
Example from beginning:
<юџ ь ю юяxя Я Я$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$GPGSA,A,1,,,,,,,5,,2VB6,
,AP,2$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$G,,5A,2S$6,
,DG,*$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$G,,2A,,S$*,
,DG1*$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$G,,2A,,S
*,D,,TN
$GNGLL,,,,,,V,N*7A
$G,,2A,21G
,G,,XN
$GNGLL,,,,,,V,N*7A
$G12*,,51G
,GN,XT
$GNGLL,,,,,,V,N*7A
$G,5*125,S
,N*,TE
$GPTXT,01,01,02,MA=CASIC*27
$GPTXT,01,01,02,HW=ATGM332D,00612063X А
$GPTXT,01,01,02,HW=ATGM332D,00612065TAC2
,,$28
0G,a301$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*712*1,5,S$,N*,,N$GNGGA,,,ь
$GPTXT,01,01M1TI1670R5010,B0CVG2*$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7AG,2
,5
*,M,,
,1N$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$GPG,2
,5
01N,T2,,N$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$GPG,5*1,.1D
,$,,PA2$GNGGA,,,,,,0,00,25.5,,,,,,*64
$GNGLL,,,,,,V,N*7A
$GP1,5A,5,B8,
$GNGLL,,,,,,V,N*7A
$GP,,.,,2V$6,G,,TA5$GNGGA,,,,,,0,00,25.5,,,,,,*64
RafaelB54 7 years ago
Hi, thanks for shared. I have a mac, do you know other software like
Visuino, thanksBoianM 7 years ago
The Visuino is quite unique design. I am working whenever I find time on MAC version, but there is so much work, that it goes slow :-( . Hope to have it done thou...
Tohoff 7 years ago
I am a newby to GPS data..
Could you help me on the
"and we can process the data from the MicroSD later on another computer."
part?
I can put $GPRMC in a decoder to get the point location.. but I want to have a complete track in the end :D
thanks
BoianM 7 years ago
There are softwares available for this processing. I have not experimented with any of them yet, but I know that others do it. You can dig around and find some ;-)
MatthijsM 7 years ago
