Introduction: Arduino Nano USB Not Recognizing (Fix).
Step 1: Arduino Nano Clones
Unfortunately an original Arduino Nano could cost you more plus shipping so it makes sense to search for an alternative source. There are also some chinese clones that are around five times cheaper, even with worldwide shipping.
But wait! There’s always a reason why a clone of something is cheaper than the original product. In this case there can be two pitfalls you need to know about.
Step 2: Original FTDI for Data Communication
Sometimes the FTDI chip which makes the USB communication possible is a counterfeit. This could cause problems when you install the official FTDI drivers and they just refuse to work.Usually there is no bootloader on the microcontroller. You need to upload it yourself and that means you need to have an appropriate programmer on hand.
Step 3: The Bad Part About Cheap Chinese Clones
So what makes this clone cheaper than the others? Well, most probably two things:
1.The headers are not installed.
2.It uses a different chip (CH340G) for serial-USB communication than the others.
The different serial chip on the other hand was something I was a little bit worried about but I’ve found my fears to be baseless. When I connected the board to the computer with a miniUSB cable it was instantly recognised by Windows as a virtual serial port.
Step 4: USB Not Recognizing
Step 5: Download Driver for CH340/CH341
The chipset used for USB-to-serial is CH340/CH341, drivers for which can be downloaded here.
http://www.wch.cn/download/CH341SER_EXE.html
Step 6:
Step 7: Unzip & Install the Driver
Step 8:
DONE!!
5 People Made This Project!
- VRguy_6 made it!
- buddhiict made it!
- mwaseemansari made it!
- Sharaddjadhavv made it!
See 1 More
55 Comments
6 months ago
Not solved.
Arduino IDE has no port active.
My computer with Windows 10 has no USB2.0-serial.
I installed the driver but Port is still not active.
Reply 3 months ago
did u solve that?
Question 3 months ago
I have Arduino Nano Initial stage I can code and upload easily. I have uploaded a code more than ten times but after that, I stuck with this issue "USB is not recognized malfunctioned" and the device manager shows Unknown Device Descriptor failed I have a tried lot of permutations and combinations But I couldn't clear the problem please anyone help me from this
Thanks
1 year ago
Thank you, you solved my problem with a Nano Clone!
Reply 3 months ago
Please tell me how did you clear that? I have a problem it says USB is not recognized malfunctioned then in device manager it shows Unknown device descriptor failed if you come across and clear please help me......
8 months ago
Problem solved, Thanks!
10 months ago
You are a genious, relatively new to Arduino, spent most of 2 nights trying to get my Surface to recognize the com port, but only when I connected the Nano, recognized the Uno just fine. Downloading the driver fixed it ... my question is how on Earth did you figure that out? Thank you, 1000x :)
11 months ago on Step 8
Omigerd! You are a godsend from the past! I just couldn't get my computer to see the Nano as a Com Port, as you said, just wanted to install as a serial usb. Went down a huge rabbit hole of USBasp programmers, bootloader programming via R3 board, etc., nothing seemed to work...then stumbled upon this. Thank you! I even had the CH341 driver installer on my computer from another project, ready to go!
1 year ago
thanks it has work for me .........kudos
1 year ago
Thank you, after 5 hours while I following many others ideas, I found your article and in 5 minutes works one chipper set based on arduino ESP8266 connected with windows 10 pc OS. Bravo!
1 year ago
Awesome! After doing a lot of research that seemed just plain wrong, I found your article. This is 100% the way to solve this problem. Thank you!
1 year ago on Introduction
You are a Godsend!
1 year ago
Thanks, solved my issue.
1 year ago
Many thanks for your post. Top guys.
1 year ago
Thank you Maggie, this just solved my problem!
1 year ago on Step 8
thank you very much !! It was vary helpful.
I had a Problem regarding not recognizing USB2.0 driver.
Worked well !!
1 year ago
I am using FTDI driver, it is working. I also tried Prolific PL2303 driver. It disappears after sometime.
2 years ago
The other BIG issue with the CH340 clone chip is that now the counterfeit nano draws roughly 80 mA from the USB source. That compares with about 17 mA when using the real nano. Just a point. Something else that I remember from about 3 months ago when I came across this same issue -- Windows 7, 8 and 10 may have to be booted up in the no-driver-signing mode. At least, at that time, the Chinese driver wasn't signed in a way that Windows trusted.
Reply 1 year ago
My Nano board uses the same CH340 clone chip. Sometime it work but other times refuse to work. After I plug in additional 9V power to the Nano Shield, it can be recognised again after restarting the Arduino IDE.
To verify my assumption, I used an USB power meter to measure the current draw through the Arduino Nano. Without the addition power connect to the shield, it draws 30mA but USB port is no longer available. The Nano board stop working too. After the auxiliary power was connected, the Nano board and USB connection resumed even without restarting the Arduino IDE. The current draw through the USB cable was 0 mA if auxiliary power was used.
2 years ago
Thanks Bro ! It worked ...
