Introduction: Arduino Nano: Ultrasonic Ranger(Ping) Distance I2C 2 X 16 LCD Display With Visuino
In this Instructable, I will show you how easy it is to connect Ultrasonic Sensor to Arduino and display the distance on a LCD Display.
Step 1: Components
- One Arduino compatible board (I use Arduino Nano, because I have one, but any other will be just fine)
- One Ultrasonic Ranger Sensor Module - I used HC-SR04, but US-015, or very much any other will also work
- One I2C 16x2 LCD Display (Back side of the LCD with the I2C adapter showed on Picture 2)
- One small Breadboard (Any breadboard can be used, or any other way to connect 3 wires together)
- 3 Female-Male (Red) jumper wires
- 6 Female-Female jumper wires
Step 2: Connect the LCD Module to the Arduino
- Connect Female-FemaleGround(Black wire), SDA(Green wire), and SCL(Yellow wire) to the LCD Module (Picture 1)
- Connect the Female end of a Female-MalePower(Red wire) to the VCC/Power pin of the LCD Module (Picture 1) , and leave the Male end unconnected
- Connect the other end of the Ground wire(Black wire) to Ground pin of the Arduino board(Picture 2)
- Connect the other end of the SDA wire(Green wire) to SDA/Analog pin 4 of the Arduino Nano board(Picture 2)
- Connect the other end of the SCL wire(Yellow wire) to SCL/Analog pin 5 of the Arduino Nano board(Picture 2)
- Connect another Female-Male Power wire(Red wire) to the 5V Power pin of the Arduino board(Picture 2), and leave the Male end unconnected
- Picture 3 shows where are the Ground, 5V Power, SDA/Analog pin 4, and SCL/Analog pin 5 pins of the Arduino Nano
Step 3: Connect the Ultrasonic Ranger to Arduino
- Connect Ground(Black wire), Power(Red wire), Trigger(Brown wire), and Echo(Purple wire) to the Ultrasonic Ranger Sensor Module (Picture 1)
- Connect the Male ends of the 3 Power wires(Red wires) - from the Display, the Ultrasonic Ranger Module, and the Arduino together as example with the help of a Breadboard (Picture 2) - In my case I used a small Breadboard
- Connect the other end of the Ground wire(Black wire) to Ground pin of the Arduino board(Picture 3)
- Connect the other end of the Trigger wire(Brown wire) to Digital pin 2 of the Arduino board(Picture 3)
- Connect the other end of the Echo wire(Purple wire) to Digital pin 3 of the Arduino board(Picture 3)
- Picture 4 shows in Red where are the Ground, Digital 2, and Digital 3 pins of the Arduino Nano(In Blue are shown the connections made in the previous step)
Step 4: Start Visuino, and Select the Arduino Board Type
To start programming the Arduino, you will need to have the Arduino IDE installed from here: http://www.arduino.cc/ .
Please be aware that there are some critical bugs in Arduino IDE 1.6.6.
Make sure that you install 1.6.7 or higher, otherwise this Instructable will not work!
The Visuino: https://www.visuino.com also needs to be installed.
Step 5: In Visuino: Add and Connect Ultrasonic Ranger Component
- Type "sonic" in the Filter box of the Component Toolbox then select the "Ultrasonic Ranger(Ping)" component (Picture 1), and drop it in the design area
- In the Object Inspector set the value of the "PauseTime" property of the UltrasonicRanger1 to 1000 (Picture 2) This will give 1 second period between the measurements, so the LCD display will not be updated too often
- Connect the "Ping(Trigger)" pin of the UltrasonicRanger1 component to the "Digital" input pin of the Digital[ 2 ] channel of the Arduino component (Picture 3)
- Connect the "Out" pin of the Digital[ 3 ] channel of the Arduino component to the "Echo" input pin of the UltrasonicRanger1 component (Picture 4)
Step 6: In Visuino: Add LCD Component, and Text Field in It
- Type "lcd" in the Filter box of the Component Toolbox then select the "Liquid Crystal Display (LCD) - I2C" component (Picture 1), and drop it in the design area
- Click on the "Tools" button (Picture 2) to open the "Elements" editor (Picture 3)
We will add a Text field with the description of the value:
- Add Text field for the Distance description text by select the "Text Field" in the right window of the "Elements" editor, and clicking on the "+" button on the left (Picture 3)
- In the Object Inspector set the "Initial Value" property of the element to "Distance:" (Picture 4) - This will specify the text to be displayed
Step 7: In Visuino: Add, and Setup Analog Value Element to Display the Distance
- Add Analog field for the Distance value by selecting the "Analog Field" in the right window of the "Elements" editor, and clicking on the "+" button on the left (Picture 1)
- In the Object Inspector set the "Precision" property of the element to "2" (Picture 2)
- In the Object Inspector set the "Row" property of the element to "1" (Picture 2) - This will specify that the field will be shown in the second row of the Display
- In the Object Inspector set the "Width" property of the element to "6" (Picture 2)
Step 8: In Visuino: Add, and Setup Text Element to Display the Units
- Add Text field for the Units text selecting the "Text Field" in the right window of the "Elements" editor, and clicking on the "+" button (Picture 1)
- In the Object Inspector set the "Column" property of the element to "7" (Picture 2)
- In the Object Inspector set the "Initial Value" property of the element to "CM" (Picture 3)
- In the Object Inspector set the "Row" property of the element to "1" (Picture 3)
- Close the Elements editor
Step 9: In Visuino: Connect the LCD Component
- Connect the "Out" pin of the UltrasonicRanger1 component (Picture 1) to the "In" pin of the "Elements.AnalogField1" element of the LiquidCrystalDisplay1 component (Picture 2)
- Connect the "Out" pin of the LiquidCrystalDisplay1 component to the to the "In" pin of the I2C channel of the Arduino component (Picture 3)
Step 10: Generate, Compile, and Upload the Arduino Code
- In Visuino, Press F9 or click on the button shown on Picture 1 to generate the Arduino code, and open the Arduino IDE
- In the Arduino IDE, click on the Upload button, to compile and upload the code (Picture 2)
Step 11: And Play...
Congratulations! You have completed the project.
Picture 1 shows the connected and powered up project. As you can see on the picture the Display will show the Distance to the nearest object from the Ultrasonic Ranger.
On Picture 2 you can see the complete Visuino diagram.
Also attached is the Visuino project, that I created for this Instructable. You can download and open it in Visuino: https://www.visuino.com
