Introduction: Arduino Ohmmeter
Arduino UNO Ohmmeter
Using a Wheatstone Bridge configuration. We will calculate the resistance of an unknown resistor using Kirchoff's Laws.
Part (1) Voltage Divider
Part (2) Calculating for Unknown Resistance
Part (3) Finished Product with Program
This example use the following:
(1) Arduino UNO
(1) External Battery Pack with (3) 1.5 Volt AA Batteries
(3) 10k Resistors
(1+) Test Resistors
(1) Software program capable serial port and ANSI emulation.
[NOTE] All electrical circuits must be handled with caution. Also I'm just an amateur trying to learn theory not a certified electrician. So if you make this circuit and are not certified. You are also an amateur trying to learn theory. Thus if you hurt yourself or your property from this post by proceeding to read or carry out actions to create the circuit that makes you in agreement that you're fully responsible for your actions.
Part 1 [Voltage Divider]
Using a voltage divider R1 and R3. [Note R1 and R3 must be the same] We can get the voltage of a external battery.
Read A0 Pin * 2 = external battery voltage (Reference between R1 and R3)
Example (1):
A0 reads 2.25 volts
2.25 * 2 = 4.5 external battery voltage.
With this arrangement of a voltage divider even if the external battery falls to 4.4 volts we can still get a good reading from our circuit.
Example (2):
A0 reads 2.2 volts
2.2 * 2 = 4.4 external battery voltage.
Step 1: Part 2
Part 2 [Calculating for Unknown Resistance]
Using the Voltage Divider in a series circuit we discovered the external battery voltage from the left bridge. Now we will create right bridge. The right bridge it will consist of R2 a known resistance. From the right bridge and Kirchhoff's law of resistance we will determine the resistance of an unknown resistor at R4 or Rx using this formula:
(Rx)ohms = 10k * A1 / ((A0 * 2) - A1)
(try to match image)
A0 = voltage read from A0 pin
A1 = voltage read from A1 pin
Example (3)
Rx = Uses 470 ohm (gold band +/- 5% difference 23.5)
A0 = 2.25 (2250mv)
A1 = .20 (200mV)
Rx = 10,000ohm * 200mV / ((2250mV * 2) - 200mV)
Rx = 2,000,000 / 4500 - 200
Rx = 2,000,000 / 4300
Rx = 465 ohm
Step 2: Part 3
Part 3 [Finished Product with Program]
(Attached are the txt file about how it works and the program)
I know this project has some weakiness yet to be discovered by myself or more likely others. However for the most part it does show how voltage and resistance measurements can take place using a Wheatstone Bridge. Allowing for other sensors to operate like a strain gauge, light sensitive diode, temperature sensor and much more.
For the software used mostly Hyperterm and VT100J emulation.
However using Putty Translation (CP866 manually type it in) with font based OEM and ANSI.
Anyone willing be to offer some *constructive* criticism to make the circuit more accurate is welcome.
Attached is the sketch for the microprocessor on the uno board: Here is the raw code:
// start copy here
#define A0IN 0
#define A1IN 1
int analogamount = 0; // used to convert voltage left bridge
int analogamount1 = 0; // used to convert voltage right bridge
float voltage = 0; // left bridge voltage
float voltage1 = 0; // right bridge voltage
float voltage2 = 0; // used for voltage correction
float answer = 0;
int cv = 0; // counter variable used screen drawing
void setup() {
analogReference(EXTERNAL); // use AREF for reference voltage
Serial.begin(9600);
set_screen();
void loop() {
analogamount = analogRead(A0IN);
analogamount1 =analogRead(A1IN);
voltage=analogamount * (4500 / 1024.00);
voltage1=analogamount1 * (4500 / 1024.00);
voltage2 = 0;
set_xy(23,1);
save_cursor_pos();
if(voltage == voltage1) {
set_xy(10,25);
repeat_char(10,0x20);
set_xy(10,47);
set_xy(14,49);
} else {
set_xy(10,25);
voltage = round(voltage);
voltage = voltage * .001;
Serial.print(voltage);
if( voltage < 1) { Serial.print("mV"); } else { Serial.print("V ");
set_xy(10,47);
voltage1 = voltage1 * .001;
Serial.print(voltage1);
if( voltage1 < 1) { Serial.print("mV"); } else { Serial.print("V ");
set_xy(14,49);
voltage2 = voltage * 2;
answer = 10000 * voltage1 / (voltage2 - voltage1); answer = round(answer);
Serial.print( (int) answer+1);
Serial.print(" Ohms ");
restore_cursor_pos();
delay(3000);
void save_cursor_pos(){
Serial.print("\x1B" "[s"); // save cursor position
void restore_cursor_pos(){
Serial.print("\x1B" "[u"); // restore cursor position
void repeat_char(int r,char c){
int rx;
for(rx = 0; rx != r; rx++){
Serial.print(c);
void set_xy(int x, int y){
Serial.print("\x1B[");
Serial.print(x);
Serial.print(";");
Serial.print(y);
Serial.print("H");
void set_screen(){
Serial.print("\x1B" "[2J");
set_xy(1,2);
Serial.print("Ohmmeter");
set_xy(3,2);
Serial.print("\xDA");
repeat_char(20,0xc4);
Serial.print("\xC2");
Serial.print("\xBF");
set_xy(4,2);
for(cv = 0; cv != 2; cv++){
Serial.print("\xB3");
repeat_char(20,0x20);
Serial.println("\xB3");
Serial.print(" ");
set_xy(6,2);
for(cv = 0; cv != 3; cv++){
Serial.print("\xB2");
Serial.println("\xB2");
Serial.print(" ");
set_xy(7,25);
Serial.print("R1 (10K)");
set_xy(9,1);
Serial.print("\xC4\xC1\xC4");
repeat_char(19,0x20);
set_xy(10,1);
Serial.print("\x1B[10;1H" " \xC4 ");
set_xy(11,1);
Serial.print("\xC4\xC4\xC4");
set_xy(12,2);
Serial.print("\xC2 ");
set_xy(13,2);
Serial.print(" ");
set_xy(16,2);
Serial.print(" ");
set_xy(18,2);
Serial.print("\xC0");
Serial.print("\xC1");
Serial.print("\xD9");
set_xy(7,46);
Serial.print("R2 (10K)");
set_xy(14,25);
Serial.print("R3 (10K)");
set_xy(14,46);
Serial.print("Rx");
} // end copy here
