Introduction: Arduino Photo Interrupter Module
Hi guys in this instructables we will learn how to use Photo Interrupter module with Arduino.
Photo Interrupter Module Keyes KY-010 for Arduino, will trigger a signal when light between the sensor's gap is blocked.
THe KY-010 Photo Interrupter module consists of an optical emitter/detector in the front and two resistors (1 kΩ and 33 Ω) in the back. The sensor uses a beam of light between de emitter an detector to check if the path between both is being blocked by an opaque object.
Step 1: Things You Need
For this instructables we will need following things :
Arduino uno
Jumper wires
Breadboard (optional)
Step 2: Schmatics
Connect the power line (middle) and ground (left) to +5V and GND respectively. Connect signal (S) to pin 3 on the Arduino.
KY-010 - Arduino
- (left) - GND
middle - +5V
S (right) - Pin 3
KY-010 - Arduino
- (left) - GND
middle - +5V
S (right) - Pin 3
Step 3: Code
Please copy the following code and upload it to your arduino Board :
int Led = 13; // define LED pin
int buttonpin = 3; // define photo interrupter signal pin
int val; //define a numeric variable
void setup()
pinMode(Led, OUTPUT); // LED pin as output
pinMode(buttonpin, INPUT); //photo interrupter pin as input
void loop()
val=digitalRead(buttonpin); //read the value of the sensor
if(val == HIGH) // turn on LED when sensor is blocked
digitalWrite(Led,HIGH);
else
digitalWrite(Led,LOW);
void setup()
void loop()
else
Step 4: Testing Photo Interrupter Module
The arduino will light up the LED (pin 13) on the Arduino when there's an object blocking the beam of light between the sensor's gap.
