Introduction: Arduino Pong
This Instructable is based on a how-to written by James Bruce:
http://www.makeuseof.com/tag/how-to-recreate-the-c...
Note: This project will not work with the Arduino Yún. An Arduino Uno, Nano or one with a similar architecture is advised.
The requirements:
1x Arduino (I used the Uno. Again, the Yún won't work)
1x 470 ohm resistor
1x 1k ohm resistor (I used a 1.1k ohm resistor)
1x Jumper wire
2x 10k ohm Potentiometer
1x RCA video cable
1x Pushbutton
1x 10k ohm resistor
Step 1: Download the TV Out Library
You can download the library (TVoutBeta1.zip) from here:
https://code.google.com/p/arduino-tvout/downloads/...
You'll want to unpack the .zip file and copy the resulting folders to either Program Files (x86)/Arduino/libraries or Documents/Arduino/libraries.
Step 2: The RCA Cable
Take on end of the RCA cable and strip the outer layer away. Gather up the shielding, twist it and put it away to one side. This is your ground. In the centre should be another cable with some plastic shielding around it. Strip this away as well. This is your signal line. Next you'll want to take your 470 ohm and 1k ohm resistor and solder them both to the signal line. Plug the 470 Ohm resistor into pin DO7 on your arduino and the 1k resistor into pin DO9. This will produce the analogue video input. After that you can take the jumper wire and solder it to the shielding outside of the RCA. This jumper wire needs to be plugged into one of your Arduino's GND pins. If you want you can test TV Out by loading in an example in the Arduino IDE (File>Examples>TVout>DemoPAL or DemoNTSC depending on your region)
Step 3: The Potentiometers
Each potentiometer should have 3 pins. The middle one needs to be connected to either A0 or A1 on your Arduino. One of the side pins (it doesn't matter which) should be connected to +5V and the other to GND. You can find a full Fritzing diagram and some pictures above. You can once again test this if you want by using an example from the Arduino IDE (File>Examples>Analog>AnalogInput)
Step 4: The Start Button
Next you'll want to wire a pushbutton to pin DO2. Again, a diagram and pictures can be found above.
Step 5: The Pong Code
You can download the Pong code (written by Lamonica and modified by duboisvb) from this pastebin:
Step 6: Have Fun!
That's everything. Pong is obviously a very simple game but you should still be able to get some fun out of it. If you want to speed the game up a bit try changing the 3 in if(frame % 3 == 0) to a 2 or even a 1. Credit goes to Alex in the comment section of the original how-to article for that one.
11 Comments
5 years ago
I'm having trouble with the code and I don't know how to solve it.
Line: void processInputs() {
Error: a function-definition is not allowed here before '{' token
If it's an easy fix please don't ridicule me, I'm just a beginner. And if you need more information tell me what you need.
6 years ago
This creative project makes use of a small CRT TV...You can probably add a clock to make it more useful.Also a sound output would be very desireable. Thumbs up
6 years ago
is there any way to control the paddles with a joystick like the original game?
Reply 6 years ago
The original Joysticks, were nothing more than Potentiometers themselves, just moving a 45-degree (<40%) travel of the potentiometer' full travel. You can make your own, putting the potentiometer through a thin panel, and connecting a "bat' level to the wiper, then simply put limits to the 45-degrees of center.. Then, comes the fun, of adjusting the arduino code, (the PONG game portion, where it reads A0 & A1) to only see the limited travel of the pots.. Just would require a little more work on the controllers. Or, are you talking the Atari 2600-Joysticks? The 2600 joysticks were only push-button. (logic 0 & 1), That would require the arduino code to react to 4 digital lines in, 2x up, and 2x down.. and require the arduino to monitor which button was pushed, and move the virtual paddle (on-screen) to match.
Reply 6 years ago
I stand with foot-in-mouth.. when I said <40%, it should've said <20%.. (divide 100/4=25, and since potentiometers only move 80% of a full circle...)
Reply 6 years ago
7 years ago
Everything was displayed on my TV, but the pots weren't moving the paddles, nor was the start button working. I tested my wiring/pots using the example sketch for analog input and they were working properly. Any ideas?
7 years ago
Just made it. It is beautiful ! Will add photos and info about it later! Very nice instructable Just needs a final photo of the screen and the Arduino working. Wans`t so sure if it was going to work! Btw what was the 10k ohm resistor for? Haven`t used it :P Discovering it was quite annoying just like an extra screw when everything is back in place ^^
Reply 7 years ago
It's for the start button (as you can see in the fritzing diagram). Not sure how you got it to work without it but oh well. Glad you had fun :)
7 years ago
I'm so trying this! :)
7 years ago
Awesome arduino project. You should enter this in the Arduino All the Things contest.
